-   -   Define conduit hanger (http://www.diychatroom.com/f18/define-conduit-hanger-90627/)
1982shawn 12-28-2010 12:57 PM
I started running the pvc conduit for my subpanel. The question is what qualifies as a conduit hanger? Its not feasable for about 15 feet for me to use conduit clamps but the only solution for the 15 feet is metal strap like plumbers use for hanging pipe. Is this against code? The conduit is 1"pvc hung horizontally in a hard to access area between 2 ducts.
Also where the conduit enters the load center, i had to use a metal lock nut on a pvc fitting because the store didnt have any pvc ones. is this ok?
secutanudu 12-28-2010 01:38 PM
I am no electrician, but I always use metal locknuts on PVC male adapters.
And I can't see a problem using metal straps to hang conduit. If you're worried, use plastic strapping, should be right next to the metal stuff.
1982shawn 12-28-2010 02:33 PM
this is what i need to know if its okay? http://www.hardwarestore.com/media/p...6_front500.jpg
AllanJ 12-28-2010 03:58 PM
That metal strap will work fine.
nap 12-28-2010 04:05 PM
metal locknuts are what you use
to the strap; I am sure I could find you a proper hanger. The plumbers strap will likely be ok unless you have a real hardcore inspector. He could shoot it down as it is not "listed for the purpose" and in a real strict definition, that purpose would be to hang electrical conduit.
what you could do it attach a "minnie" to the strap and attach the strap up wherever you are planning on attaching it.
http://minerallac.thomasnet.com/view...=100|1098|1372
there are many other possibilities as well.
1982shawn 12-28-2010 04:47 PM
Nap, thanks ill just use the minnies with the flat side down.
