Defective GFI's - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 10:37 PM   #1
Defective GFI's
Is everyone else experiencing a lot of GFI's going bad? Does anyone recommend a certain manufacturer of them that will last longer than the garbage they sell at the big boxes?
thanks
brokenhammer is offline   Reply With Quote
Old 01-11-2009, 11:45 PM   #2
Registered User
Termite's Avatar
I run into a lot of bad ones on inspections. I haven't paid a heck of a lot of attention to the brand name unfortunately, but the ones that seem to go bad (or not function) most often are the ones with the rectangular little buttons that feel like they have sand in them when you press the reset button in. The ones with rounded buttons and operate smoothly seem to have a lot less defective units.
Wish I could be more descriptive by offering a name brand...
Old 01-11-2009, 11:58 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by brokenhammer View Post
Is everyone else experiencing a lot of GFI's going bad?....
I've replaced two in the last five years, Both were on outside decks and mounted in old boxes cut into the original outside stucco walls. I suspect from the weathered appearance of the Leviton white GFCI's that water had leaked into the box.
GFCI's have a zero tolerance for water. Besides the 8 pin GFCI chip there are a number of discrete components that can fail in damp locations.
See schematic on sheet 7 of pdf:
UTC LM1851
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-12-2009, 07:30 AM   #4
Depends on location, a regular gfi cannot be used outside.
I like Pass & Seymour, Cooper wiring devices and Levition. They cost more but seem pretty sturdy.
rgsgww is offline   Reply With Quote
Old 01-12-2009, 07:37 AM   #5
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I'll second Pass & Seymour
wirenut1110 is offline   Reply With Quote
Old 01-12-2009, 07:42 AM   #6
DIYer
I have a several "builder grade" GFCIs in my 9 year old house that I've had to replace. You get what you pay for.
Gigs is offline   Reply With Quote
Old 01-12-2009, 10:30 AM   #7
Tool Geek
PaliBob's Avatar
Pass & Seymour has the the coolest devices.
Disclaimer
& Stay Safe
.....Bob Lavery
defective Schon flooring sangreia Flooring 4 01-29-2009 08:12 AM
Defective Carlin Oil Primary? Ron6519 HVAC 0 12-31-2008 09:52 AM
2 GFI's 1 nuetral? moondog111 Electrical 15 12-08-2008 09:05 AM
defective manuf. shingles johnzou Roofing/Siding 1 10-30-2008 03:08 PM
Noisy NuTone Bathroom Exhause Fan Thumbs Up Electrical 8 07-04-2008 07:53 PM
