Deep Well Submersible Pump Electronics - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 07:33 PM   #1
deep well submersible pump electronics
i installed a new pressure switch. when high pressure cut off (50 psi) is reached, pump fails to cut off. WHY?
hugh harrelson is offline   Reply With Quote
Old 01-06-2011, 07:50 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is the switch opening? Did you verify that? Is that all you did? Why did you replace the switch?
The Following User Says Thank You to nap For This Useful Post:
hugh harrelson (01-07-2011)
Old 01-06-2011, 09:24 PM   #3
joed's Avatar
Rewards Points: 12,438
You wired the switch wrong?
You installed the switch wrong and it's not seeing the pressure?
The plumbing is clogged and the switch is not seeing the pressure?
The pressure gauge is wrong and the pump is not pumping up to pressure so the switch never sees the cutoff point?
The Following User Says Thank You to joed For This Useful Post:
Old 01-07-2011, 09:37 AM   #4
I=E/R
a7ecorsair's Avatar
There could be a variation between the gauge reading and the switch setting. What happens if you don't turn off the pump, will it pump up to 55#? Why did you change the switch?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 01-07-2011, 09:17 PM   #5
well problem
I cut the power on;pump runs; tank psi increases to above the cut off set point of 50 (30/50 pressure switch); pump continues to run; at 60+ I begin bleeding so that pressure does not go higher. I stop the bleeding; pressure now is reduced to mid 40s; I crawl from under my house and cut power to the pump. I installed a new pressure switch because on two previous occasions this problem was corrected when a new switch was installed. I did not remove the switch cover but assume, maybe incorrectly, that the contacts were still closed during all of this. Could the control box be the problem? Thanks for your input. Looking forward to your reply.
Old 01-07-2011, 09:40 PM   #6
nap
You talking to me?
nap's Avatar
make sure the water path from the pressure switch to the water pipe that feeds it is clear. A lot of time you can get sediment build up in small passageways that do not allow the pressure to actually reach the switch. Since the gages are usually not on the same little feeder pipe, it might be clean and show proper pressure.
So, take off the pressure switch. Look in it to make sure you haven't gotten some crud pushed up on the switch. Then clean out the pipe it mounts to with a wire or small brush. If you have somebody to help you, you could actually flip the pump on at the point to be sure you get flow. Use a cup or something over the opening to keep it from spraying all over (especially since you are working with electricity at this point.)
Once you are sure that is clear, put the switch back on and try again.
Old 01-08-2011, 09:52 AM   #7
" Euro " electrician
frenchelectrican's Avatar
What brand pressure switch you have there ?
Is any cold air is hitting the pressure switch because in some area when the cold air hit the pressure switch or small pipe they can get semi frozed up and may not let the switch function properly as Nap mention to clear out the gunk.
Did you get a new pressure gauge somecase the gauge can be bad as well those gauge should be under 15 Euros so that will be a good time to do it.
And did you do any adjustment with the pressure switch as well?
Last thing when you screw on the new pressure switch MAKE SURE that you do not let the teflon tape get too close to end of the pipe due some case teflon tape can actaually block the pressure switch port which it have very small opening.
Merci.
Marc
Plumbing submersible well pump cwalt43 Plumbing 0 09-27-2010 05:08 PM
Submersible pump plumbing cwalt43 Plumbing 0 09-15-2010 11:25 AM
submersible well pump . first start. ryanh Plumbing 11 07-12-2010 09:26 AM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
power to submersible well pump erlindbl Electrical 24 02-08-2009 09:17 PM
