Deep Freezer Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 09:56 PM   #1
Deep Freezer Help
I currently own an old Kenmore Chest Freezer. Model # 198.8173815. I currently have it plugged in to its own separate 120V wall outlet. I am about to move and I know there are no seperate 120V wall outlets where I am going to place the freezer in the new house. My question is....can I just plug it into a regular wall outlet in the garage...Prob. 115V or should I get an electrician to wire a seperate 120V to where I am going to put the deep freeze.
According to the tag on the freezer here is all I know about it:
4.4 Amps....60 Hz....1 Phase.....115 Volts.....DOM:01/86
Thanks for any help!!!
dcrolin is offline   Reply With Quote
Old 03-23-2009, 11:58 PM   #2
Idiot Emeritus
Rewards Points: 1,476
My first choice for a food freezer is to plug it in to a single receptacle that's connected to a lighting circuit. That way you'll know if it has lost power. Food is expensive!
My second choice is a dedicated circuit.
Since the current is low, it'll likely work just fine on any circuit available.
One thing to watch out for, sometimes there's a GFI receptacle in the garage, and the bathroom receptacles are fed from it. This way, the bath receptacles are GFI protected, as required by code, but it's often a 15 amp circuit. A hairdryer loads a 15 amp circuit to the gills, and if the freezer is running, it might trip the breaker.
Rob
micromind is offline   Reply With Quote
Old 03-24-2009, 04:38 AM   #3
dSilanskas's Avatar
Your fine it doesn't draw that much you can plug it into whatever you want.
dSilanskas is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Hotpoint freezer cool fridge too cool Maddyrosedad Appliances 1 02-19-2009 05:38 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 12-31-2008 11:08 PM
Freezer on top, not freezing any more. kgphoto Appliances 7 06-23-2008 10:00 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
