Deep Cycle Battery Charger With Float Mode - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 06:12 AM   #1
Rewards Points: 1,050
Deep cycle battery charger with float mode
Hello
I am looking to install a battery backup sump pump in my basement
I've read that the Wayne ESP25 was a good model, but the included charger was crap
What charger with trickle/float mode would you recommend (a charger that will normally charge the battery but will switch to trickle mode when it's full)
And if I don't want to buy the whole kit, what 12V sump pump could I buy? or is it better to run a 120V pump off the battery with an DC/AC inverter?
french_guy is offline   Reply With Quote
Old 01-31-2013, 06:46 AM   #2
custom user
Rewards Points: 150
I've had great luck with the Schumacher brand. Inexpensive and works well on my truck and motorcycles. Works as well as the more expensive Battery tender. One thing to check is compatibility with gell cells if that's the way you're going.
JasperST is offline   Reply With Quote
Old 01-31-2013, 07:40 AM   #3
I was thinking about "Marine batteries"
But it can be confusing between the different type (Regular, AGM, Gell cell)
I was thinking to go take a look at Walmart to find this model
http://www.walmart.com/ip/EverStart-...ttery/16795212
So what is the exact type?
At this price, I could put 2 in parallel to have extended run time
And I was thinking to buy this charger:
http://www.walmart.com/ip/Schumacher...arger/15140196
What do you think?
Old 01-31-2013, 08:47 AM   #4
custom user
Rewards Points: 150
What do you think?
That one seems to be geared more toward charging, not maintenance. The float charger is meant to stay plugged in and this one works great for my large capacity F150 truck battery:
http://www.walmart.com/ip/Schumacher...arger/13005742
But it's going to depend on the work load, a small maintainer won't keep up if the battery is regularly being used. Why can't you run a 120v line to a pump?
Old 01-31-2013, 09:29 AM   #5
I am looking at a backup when power is off
I do have a generator, but would like a back up IF power goes off during the night for example, or if my main pump were to have an issue (with or without power actually). So to summarize by priority order:
1) Battery operated sump pump backup in case of a power outage, especially during the night - even if the run time will only be 1 day with a fully charged battery, it will give some time to react
2) And with or without power outage, it will serve as a backup if my primary pump or sensor were to have problems
Even if I buy the Wayne ESP25, I will have to buy a battery and a charger since the one delivered with it is not great.....
I've read that AGM batteries are best (and safe), but they are expensive....
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
How to connect my battery to my solar charger? rdlrn19 Green Home Improvement 0 02-26-2010 05:30 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 09:50 PM
modify battery charger geeyathink Electrical 1 08-03-2006 04:36 AM
