Dedicated Outlet For Undercounter Fridge? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 08:00 PM   #1
Rewards Points: 640
dedicated outlet for undercounter fridge?
I know normal size fridges require a dedicated outlet, but what about smaller under counter fridges? What does the NEC say about this situation? thanks!
BlueBSH is offline   Reply With Quote
Old 11-24-2011, 08:31 PM   #2
Rewards Points: 150
As far as I know they do not discriminate with regards to the size of the fridge.
OhioHomeDoctor is offline   Reply With Quote
Old 11-24-2011, 09:56 PM   #3
Licensed electrician
Rewards Points: 1,864
Regular refrigerators do not require a dedicated circuit. A large Sub-zero style would.
Speedy Petey (11-24-2011)
Old 11-24-2011, 10:22 PM   #4
Rewards Points: 640
really? they wouldn't pass our kitchen until the fridge had a dedicated circuit and they claimed it was a NEC requirement
Old 11-24-2011, 10:39 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Unless the instructions for the refrigerator requires a dedicated circuit, the NEC doesn’t require a dedicated circuit for refrigeration equipment in a kitchen. It’s allowed to be, but not required.
Kyle
Old 11-24-2011, 11:28 PM   #6
Rewards Points: 640
alrighty! when they try to say its required ill say show me where its in the code
Old 11-25-2011, 02:37 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,108
It's not in the code to put it on a dedicated ckt....but the code does say that the fridge is exempt from a GFI ckt.
The 'standard' is to provide the fridge with it's own breaker....that way you don't have to worry about the microwave tripping the breaker that the fridge is on...just like it's a common standard to put lights on seperate breakers from wall outlets...that way your not in the dark when the hair dryer and vacuum on the same ckt trips the breaker.
ddawg16 is online now   Reply With Quote
Old 11-25-2011, 06:17 AM   #8
Rewards Points: 1,216
Try not to argue with the inspector you might win but your going to lose. Don't sound right does it? Arguing with an inspector is like wrestling in the mud with a pig the more you argue the more he likes it.
COLDIRON is offline   Reply With Quote
Old 11-25-2011, 07:29 AM   #9
joed's Avatar
Rewards Points: 13,690
While not in the NATIONAL code it could be a local requirement.
In Canada it is a requirement. Mini fridges of less than 5.5 Cu ft capacity are exempt.
Old 11-25-2011, 12:24 PM   #10
Rewards Points: 640
this is for a basement bar, we dont have plans for a microwave, but guess you can never be sure huh
Installing dedicated outlet for generator only iabteri Electrical 21 12-13-2013 02:46 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
is 20a outlet required for a fridge? mrpep Appliances 3 11-22-2009 08:42 PM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 06:25 PM
