Dedicated Ciruit For AC And Single Receptacle... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 05-04-2013, 11:22 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What some may fail to realize is that there are other users that search these boards for answers without actually posting their question. When inaccurate information is given, it may relate to the question these users want answers to and they may create a code violation/safety hazard using this bad information.
Last edited by beenthere; 05-05-2013 at 08:21 AM. Reason: rephrased to no individual reference
k_buz is offline
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (05-05-2013)
Old 05-04-2013, 11:22 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by sirsparksalot
damn, stick, what'd you do?
you know, shared knowledge and code logistics, the type of info you cant buy, but get for free...
stickboy1375 is offline
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
electures (05-05-2013), Philly Master (05-05-2013), sirsparksalot (05-04-2013)
Old 05-04-2013, 11:29 PM   #18
Rewards Points: 512
yep, we appreciate it
Installation is the Reverse of Removal.
sirsparksalot is offline
The Following User Says Thank You to sirsparksalot For This Useful Post:
Old 05-05-2013, 07:22 AM   #19
Licensed electrician
Rewards Points: 1,634
Originally Posted by gregzoll View Post
Yes it is not my decision to make, but I have warned you about Trollboy, so watch your back. If there is anyone that loves to argue about pointless stuff, Stickboy is that person.
So you are saying that the incorrect information you posted in post #8 shoulld not have been refuted?
Also Philly Master in post #7 posted information that pertained to duplexes that is correct. However, the topic was about individual branch circuits and simplex receptacles.
Jim Port is offline
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
electures (05-05-2013), Philly Master (05-05-2013), stickboy1375 (05-05-2013)
Old 05-05-2013, 08:27 AM   #20
An old Tradesmen
Rewards Points: 7,414
Originally Posted by zephed666 View Post
Just want to make sure it is ok to use single receptacles on my dedicated cirucits for my ACs.
A wise thing to do.
beenthere is offline
The Following 2 Users Say Thank You to beenthere For This Useful Post:
Old 05-05-2013, 10:09 AM   #21
Rewards Points: 6,652
Jim no I am not stating that there was incorrect info given in post 8. It is just that there are some that go too far in depth on the threads, with unneeded info.
I look at it this way, that if the OP wanted to know about codes, they would ask about those regarding the use of the single outlet unit on a circuit and why.
I have stated this the past couple of weekes that these threads are turning into code compliance, and big arguments about stuff, that the op has never asked about, or even probably wants or cares about.
gregzoll is offline
Old 05-05-2013, 10:16 AM   #22
An old Tradesmen
Code compliance is important. Weather or not an OP ask or thinks about it. It would be neglectful for the Pros answering the questions not to point out code requirements/restrictions/violations.
When an OP continues to state they are going to ignore code and do unsafe acts, we close and or remove that thread.
electures (05-05-2013), stickboy1375 (05-05-2013)
Old 05-05-2013, 10:22 AM   #23
I have stated this the past couple of weeks that these threads are turning into code compliance, and big arguments about stuff, that the op has never asked about, or even probably wants or cares about.
That is ludacris. If the OP knew information like that they probably would not need to ask a question. It is when people with additional knowledge bring additional facts into the topic that nuances like the need to use a circuit rated simplex are brought out. Adding info so the codes can be followed is helpful and responsible.
Jim Port is offline
Old 05-05-2013, 11:33 AM   #24
Beenthere, yes it is important, but the OP never asked about it, nor did I see them question the need to have the citations pulled. This stuff happens on every electrical thread, that really at most should be short, but end up being full of code cites and negative feedback when others contribute a question or opinion as to why someone is quoting information that has nothing to do with what the original question is.
All the OP asked was if it was okay to use that single outlet, and what circuit amp it was going to be on. The answers should have been what the restrictions are in using on a branch circuit and why it is, not go so far in depth, that it ended up being a class on electrical codes.
gregzoll is offline
Old 05-05-2013, 11:36 AM   #25
E2 Electrician
Greg, you can always start your own Electrical Forum if you don't like it here.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 05-05-2013, 11:36 AM   #26
Also beenthere, if they choose to ignore code, there is nothing we can do about that outside this forum. Really if they choose to ignore information and how they want to do it, we did our job by explaining the whys and how.
After they leave here, it is ultimately up to the man above to give them a wakeup if something happens.
gregzoll is offline
Old 05-05-2013, 11:39 AM   #27
An old Tradesmen
Now that everyone has had their say.
Thread closed.
The Following User Says Thank You to beenthere For This Useful Post:
Closed Thread
3 way, 4 way, Single Pole/3-Way Combinations slash5bmw Electrical 5 06-22-2010 07:21 AM
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 07:51 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
