Dedicated Circuits For ACs - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 08:17 AM   #1
Rewards Points: 172
Dedicated circuits for ACs
Hello:
I have 3 wall AC units and 3 dedicated lines for each. One line is 20A and the other 2 are 15A lines. My question is should the 15A dedicated lines have single receptacles like the 20A line. They currently have duplex receptacles.
Thanks!
zephed666 is offline   Reply With Quote
Old 03-23-2011, 08:25 AM   #2
I=E/R
a7ecorsair's Avatar
Originally Posted by zephed666 View Post
Hello:
Thanks!
What is the current rating of the two 120V 15A units? Should be on a tag close to where the power cord attaches. I would put in a single receptacle just to prevent anything else from using the circuit.
a7ecorsair is offline   Reply With Quote
Old 03-23-2011, 08:32 AM   #3
Rewards Points: 172
We never plug anything else into the outlets. Just curious if it is necessary. I was under the impression a 20A dedicated line needs to be a single receptacle according to code. Just wondering if the 15A line needs to be as well. I am not an electrician so I do not know...
Old 03-23-2011, 08:45 AM   #4
I=E/R
a7ecorsair's Avatar
As long as the AC load doesn't exceed 80% of the circuit capacity you are fine.
Old 03-23-2011, 08:54 AM   #5
Rewards Points: 172
Is the 20A single required by code? Just curious now.
Old 03-23-2011, 09:01 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
In the case of branch circuits that supply only receptacles, it's only considered a dedicated line (individual branch circuit) if the receptacle is a single receptacle. A duplex is 2 receptacles. Once a duplex is installed, it's no longer a dedicated circuit, even though nothing else is supplied by that circuit.
As Corsair said, if you don't exceed 80% (12 amps) you're ok.
Kyle
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Need a bunch of dedicated circuits in one area Red Squirrel Electrical 9 01-15-2011 04:17 PM
Dedicated circuits in the home? viper Electrical 18 10-01-2010 03:20 PM
AFCIs/GFCIs for dedicated appliance circuits tigereye Electrical 5 12-02-2009 11:17 AM
15A receptacle circuits in kitchen _in addition to_ 2x 20A? WaldenL Electrical 4 09-18-2009 04:58 PM
