Dedicated Circuit For Table Saw - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 10:41 AM   #1
dedicated circuit for table saw
I am looking to have a dedicated circuit only for my table saw installed in my barn.
the tablesaw is wired to operation on 220V circuit with following specs:
Nominal voltage 220V/240V
Circuit rating: 20 Amps
questions:
what is the minimum conductor size required for this circuit?
is 20 Amp sufficient or should I look at 30A ?
how or what is the difference in the wiring issues or proceedures for 220 vs. a 240v? is it the same?
thanks
MeanGene is offline   Reply With Quote
Old 11-03-2010, 10:55 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
questions:
thanks
20 amp#12 wire
220/240 same voltage
Old 11-03-2010, 11:15 AM   #3
Originally Posted by jbfan View Post
20 amp#12 wire
What he said! If you are pulling threw conduit stranded is a good option. Pulls a little easier.
HOHelper is offline   Reply With Quote
Old 11-03-2010, 11:46 AM   #4
thanks...with 20A, then I dont need any "Head room" for amperage if it is the only item on circuit?
just a double pole 20 A works huh?
Old 11-03-2010, 12:22 PM   #5
jbfan's Avatar
Rewards Points: 246
Thats it.
The Following User Says Thank You to jbfan For This Useful Post:
MeanGene (11-03-2010)
Old 11-03-2010, 08:37 PM   #6
" Euro " electrician
frenchelectrican's Avatar
For straight 240 volts circuit they do not need netual at all so pay attetion to the conductor colour choice here.,,
If you run in the conduit you can use the 4.0mm˛ { #12 AWG } with Red , Black and Green conductors that work just fine with 20 amp two pole breaker.
However if you have to use the NM for some reason this will change the tune a little so pay attetion here per NEC / CEC { I am pretty sure on that part } codes they are allowed to remark the white conductor to diffrent colours typically any colours as long it is NOT White , Green , Gray those three colours are off limit they are reserved for purpose.
And remark at BOTH ends of the cable so you know it is legit 240 volts circuit the 4.0mm˛ Twinner { 12-2 NM } cable is common used.
Merci.
Marc
Old 11-03-2010, 09:31 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you don't need anything greater because of this:
they are not listing the current draw with that. They are telling you what size of circuit to actually use. They took all of the calculations out of the process already.
The Following User Says Thank You to nap For This Useful Post:
MeanGene (11-04-2010)
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 10:12 AM
Planning circuit layout for barn tbeaulieu Electrical 8 04-08-2010 10:38 AM
Moving a Fridge, is a dedicated circuit required...or not? Snowy334 Electrical 7 07-03-2009 01:36 PM
Dedicated 20amp circuit chingon Electrical 1 03-31-2009 07:36 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 10:07 AM
