-   -   Dedicated Circuit (http://www.diychatroom.com/f18/dedicated-circuit-95736/)
RalphPeters 02-17-2011 04:54 PM
Dedicated Circuit
I'm installing a whirlpool type tub that requires two 15a GFCI protected circuits. One for the pump and one for the heater. I want to use blank faced GFCI outlet that will be located in an adjacent closet.
-Can both of these circuits enter a common 2 gang outlet box and get wired to a split receptacle since both circuits are running to the same location if all wires are kept separate besides the ground?
-Is there a problem in running electrical cable past plumbing lines?
brric 02-17-2011 04:58 PM
You will need separate GFCIs for each circuit.
RalphPeters 02-17-2011 05:01 PM
Yes I plan on using two two blank faced GFCI's. Can they be mounted in a two gang box, same thing with the outlet box?
kbsparky 02-17-2011 05:01 PM
To answer the OP, YES!
You can mount both blank-faced GFCI units in a 2-gang box, and then feed a split-wired outlet under the tub.
Be sure to remove both interconnection tabs on the split-wired outlet.
RalphPeters 02-17-2011 05:03 PM
OK Thanks.
So no problem with plumbing lines and electrical cable?
darren 02-17-2011 05:05 PM
If you do this you will need to bring 2 two wire cables to the plug and break off each side of the plug. If you run a 3 wire you will have nuiance tripping of the GFI.
kbsparky 02-17-2011 05:06 PM
I'd use a 4-wire cable. Do that have that available in Canada?
As long as you don't install the wires inside of those plumbing pipes, you should be good to go.
RalphPeters 02-17-2011 05:11 PM
I was planning on running two 14-2 cables but if I can run just one cable from the breaker box it makes it a lot easier.
darren 02-17-2011 05:31 PM
You can use a 14/3 from the panel to the GFCI as long as you pigtail the neutral at them. From the GFI you will need two 14/2 to the plug. I have never seen 4 wire lomex but you can get 4 wire BX, if you get 4 wire BX techincally you would have to derate because you have more then 3 current carrying conductors. So for a 15A breaker you would have to use 12/4.
Jeter 02-17-2011 06:22 PM
The easiest way to do this is, run 2 separate 14/2 , always a good
Idea not to share neutral when running two motors, put the GFI's at the panel (easy to reset if GFI trips) then run your individual 14/2 to regular plugs near your tub or wherever u were going to put them. Keeping the motors separate, by running 2-14/2's is good if there's ever a problem with either the pump or heater, easy to figure out which is having trouble if it was to have own feed
SPINA ELECTRIC 02-19-2011 08:49 AM
I have to agree with brric depending on the draw of the tub and the heater I would have a seperate GFI for each one and each would be a 20 amp line right under the tub with an accessible door.
RalphPeters 02-22-2011 04:21 PM
It seems that all faceless GFCI's are rated at 20 amp. Is that OK on a 15 amp circuit?
http://www.leviton.com/OA_HTML/ibeCC...minisite=10026
Specs say :
General Information
GFCI ratings:
15A-125V AC - Cat No. 7599 Duplex
Receptacle
20A-125V AC - Cat. No. 7590 Faceless
20A-125V AC - Cat. No. 7899 Duplex
Receptacle
All devices rated 20A feed-through
brric 02-22-2011 04:34 PM
No problem.
RalphPeters 02-22-2011 05:14 PM
