Dedicated Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 07:48 PM   #1
Dedicated circuit
I had intentions of installing a 20 amp circuit. It was simple enough I thought; just connect the neutral wire to the neutral bar, and the ground to the ground bar, and the hot to the breaker.... When I removed the cover, I couldn't tell which was the ground bar or which was the neutral. The box had neutral wires and ground wires attached to the same bar on both sides. Now I am confused. Can I attach the neutral, and the ground wires to the same bar?
Thanks,
lch
lchenderson is offline   Reply With Quote
Old 02-24-2012, 08:04 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If it's the main panel and both of the bars are supposed to be bonded together.
I still like to keep neutrals and grounds separate even though the bars are bonded.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-25-2012, 08:39 AM   #3
Rewards Points: 160
You're fine connecting both to the same bar. Yes, it is better to keep them separated, but you'll be fine connecting the 2 to the same bar.
matt151617 is offline   Reply With Quote
The Following User Says Thank You to matt151617 For This Useful Post:
lchenderson (02-25-2012)
Old 02-25-2012, 08:45 AM   #4
Thank you for your reply. It is the main panel. Because it is the way it is, I assume it was meant to be bonded??
Old 02-25-2012, 08:55 AM   #5
Licensed electrician
Rewards Points: 1,780
The neutral buss is required to be bonded in the service panel.
Old 02-25-2012, 09:54 AM   #6
Thanks Jim. That eases this novice's mind...
Old 02-25-2012, 10:03 AM   #7
Thanks Matt
Old 02-25-2012, 02:00 PM   #8
jbfan's Avatar
Rewards Points: 552
Remember that the ground wire can usually be 2 under one screw, but the white wires can have one under each screw.
Old 02-25-2012, 04:36 PM   #9
Yes.
I suppose that the current capacity of the bonding method is the same or better than each busbar's capacity.
dedicated circuit for gas stove & hood? acerunner Electrical 3 09-30-2011 05:58 PM
Why a dedicated line? tmorriss Electrical 16 02-22-2011 07:53 PM
Moving a Fridge, is a dedicated circuit required...or not? Snowy334 Electrical 7 07-03-2009 12:36 PM
Dedicated 20amp circuit chingon Electrical 1 03-31-2009 06:36 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
