I like the idea of the decorative fan where it looks just like a normal light fixture, but I wish even the really quiet 2.5 sone models were a bit quieter (but it's still OK). The bad part is that the customer reviews for these say that they are so quiet that you can't hear them.
The idea of inline fans seems nice, but I wonder if they really are that much quieter? People say that inline fans are incredibly quiet, but are they the same hearing-impaired people like those that wrote the reviews on other fans?
In have 3 Fantech fans installed at my house. If the fan is sufficiently remote you don't hear the motor, but you do hear the movement of the air-flow though the intake grills.
I guess it depends on where the inline fan is in relation to your vent. The further away it is, the less likely you will hear the fan through the duct work. Large office buildings usually have some sort of central fan for their bathroom vents. Typically, all you can hear is the sound of the air being sucked into the vent.
The only thing I'm worried about is that the fan, even though it will be in the attic, will be about 3½ feet from the bathroom wall. See the attached diagram.
mtk369 most inline fans in the 4" to 6" range I've come across are typically rated around 2.2 to 2.8 sones. So they're not all that noisey to begin with. Of course these are not usually tested within a duct so the actual noise level you get could be considerably different. But way I see it as long as that fan is not located close to your vent outlet whatever noise the fan does generate should be a non-issue. The sound of passing air should be all the noise you'll have to contend with.
Cheers,
ChrisFixit
edit: Just saw your diagram. Whats the sone rating on the fan?
I recently installed an inline fan and love it. All you hear is the sound of air flow. The problem with the inceiling fans is they may be quiet at first but they are made very cheap and get loud and out of balance within months.
@nap I was curious about isolating mounts. I couldn't find anything from Fantech save the standard mounts. So I was wondering if true isolating mounts couldn't be found, would using the standard mount with a dampening material (rubber mat material, insulating foam, weather stripping, etc) work as a substitute. I know I sometimes use this method when tinkering inside my computer to keep its noise level down.
My case came with grommets that completely surround the screw holes in the case (even on the inside of the hole), that way they can't transmit vibration. I wonder if something like that would be possible, or if that's how they make vibration-reducing mounts.
They are so quiet I would hardly even worry about the way it's mounted. Of course every bit helps, and fans may vary. I have mine hanged using plumbers tape, and some pieces of copper wire to prevent the fan from being able to slide out. When I go downstairs (where I mounted it) I don't even know it's on if the dehumidifier is running.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
