Decora Rocker Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2013, 11:04 AM   #1
Rewards Points: 1,600
Decora rocker switches
For a standard toggle switch, it's consistent. You flip the switch UP to turn ON, the switch points down it's OFF.
What is the standard for a decora rocker switch?
I know there may not be a standard but may be at least a common convention? Similar to a receptacle you can mount it however but most would do it with the ground in the middle facing down.
For a rocker do you press the TOP of the rocker to switch it ON or OFF?
I have some one way and some another way in different rooms done bt different people over time, drives me crazy especially those switched receptacle no way to tell visually. At least for a light if it's lit it's ON if it's not lit then OFF or bad bulb.
Which way is a rocker supposed to be mounted?
miamicuse is online now   Reply With Quote
Old 08-27-2013, 11:09 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
There should be a stamped label that has the word TOP for the switch.
The only difference is the decora doesn't have on/of on them.
Old 08-27-2013, 12:51 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
For a 2 pole Decora press the top to turn the switch on. For 3 and 4 pole Decora (and standard toggles) there is no on or off.
And not everyone agrees that a receptacle ground should be down (there is no code).
Coastal South Carolina
Old 08-27-2013, 06:49 PM   #4
joed's Avatar
Rewards Points: 11,972
Agree. Press the top of a rocker to turn on.
Old 08-28-2013, 01:49 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Most case you will find the word TOP stamped on the metal yoke so you can not miss that unless it was paint covered then look at the termation screws that will be a give away answer.
Merci,
Marc
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 01:37 PM
Needed Decora rocker switch CFL rated? rodm1 Electrical 10 08-25-2012 06:29 AM
Bath Exhaust Fan Timer Switch--2 Switches in Series hammerlane Electrical 5 01-07-2012 07:09 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 04:21 PM
Quiet decora light switches?? murray59 Electrical 6 04-18-2008 12:37 PM
