Deck Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2009, 10:43 AM   #1
Deck lighting
Im looking to string together some lights and place them on a electric time to be turned off and on automatically at night. Im a newb when it comes to electricity so I wanted to see if a professional had any input on how many lights strung together were safe with the equipment im using.
I want to use this timer...
http://www.amazon.com/Intermatic-TN7...8449710&sr=8-8
And these lights...
http://www.homedepot.com/webapp/wcs/...016+4294887768
And 16 guage wire to string them together.
How many can I safely string together and not have to worry about overloading anything when plugging them into a regular wall socket?
Thanks!
doomsday123 is offline   Reply With Quote
Old 07-24-2009, 10:55 AM   #2
What are you going to install the bulbs in - socket/lamp assembly?
Where/how will these be mounted on the deck?
Temp installation - summer?
I think any inspector woudllwant 14g wire rated for outdoor use & permanent fixtures
Old 07-24-2009, 11:04 AM   #3
They will be installed via this type of sockets...
http://www.lowes.com/lowes/lkn?actio...P-L&lpage=none
The use will be for an outside porch.
Old 07-24-2009, 11:18 AM   #4
Nah. . .
Old 07-24-2009, 11:19 AM   #5
What???
Old 07-24-2009, 11:22 AM   #6
What???
That means that the wiring you want to use (as far as I know) does not meet code
When a building is under construction these use something like that as Temp lights
Need an electrician/code person to weigh in
I know soem codes - but not all
Old 07-24-2009, 11:27 AM   #7
Well this will not be permanent. I am just making sure I don't burn anything down. I am looking for a quick fix while I am in the process of figuring out what permanent fixtures I want. 6-8 would be ideal but can do less if its not safe. Thats a total of 184 watts max and im not really sure of the amperage of the lights or how to calculate it. I am also not sure if there is another measurement that I need to look at.
Old 07-24-2009, 11:47 AM   #8
The problem is that all splices must take place in an approved box
How many lights you can connect is limited by:
#1 Circuit size: 15a = 1800watts, 20a = 2400 watts
#2 Fixture - Max bulb that can be installed
That connection indicates 660w Max - doesn't seem correct
I'm not sure a CFL bulb can be left exposed to the weather
Mine are all located inside of a fixture
Old 07-24-2009, 11:54 AM   #9
The CFL lights will be on an enclosed porch so the only thing weather wise that they will be exposed to is the temperature. Plus since they are a temporary solution im not sure how long they are even going to be used. So assuming that the limiting factors above are correct then I should be fine running 8 lights as long as the wiring is adequate. Is 16 gauge wire adequate?
Old 07-24-2009, 12:18 PM   #10
Electrical Contractor
Try These lights.
http://www.sivallighting.com/-heavy-...ng-lights.aspx
hpp58 is offline   Reply With Quote
Old 07-24-2009, 12:23 PM   #11
Semi-Pro Electro-Geek
Rewards Points: 2,968
No, 16 AWG is not adequate. This circuit will be protected by a 15 or 20A breaker, so a minimum of 14 AWG or 12 AWG wire is needed. Those sockets are the wrong choice, too. They require individual wire-nutted connections at each socket, which cannot be made to code (or even safe, really). I would really recommend not doing this - you don't seem to have enough electrical knowledge to make a safe installation. Why don't you just buy a premade light string? Plenty of places sell them. I've even seen them at Lowes.
If you insist on making your own light string, use a socket like this:
It self-pierces the insulation on the wire, so you don't need to make connections at each socket and the wire is continuous for the whole string. You can easily suspend the sockets from their hooks, so the weight is not resting on the wires. Use 12 AWG THHN wire. Be sure to insulate the cut ends at the far end of the light string using wire nuts. Technically, that kind of light string should not be connected with a plug since plugs are not listed for use with THHN wire, but that's what you'll have to do to connect to the timer you have chosen.
Make ABSOLUTELY SURE this is connected to a working GFCI circuit. Light strings like this pose a much greater shock hazard than most other types of installations, and a GFCI is really a necessity.
Your timer is rated for 1675W (14A), so you could use up to that much lighting. With CFL, that's a very large number of lamps. Overload will not be an issue.
mpoulton is online now   Reply With Quote
Old 07-24-2009, 12:31 PM   #12
210.3 Stated that the minimum branch circuit is 15 amps thus 14 gauge wire.
590.2 Except as specifically modified in this artical, all other requirements of this code for permanent wiring shall apply to temporary wiring installations
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Outdoor Lighting For Deck cwalker6 Electrical 3 05-20-2009 06:39 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
