Dead Receptacles/circuit Breakers - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 05:56 PM   #16
DIY staff
Rewards Points: 7,174
Get yourself a two wire electrical tester---a $4 neon tester will do----when you have one come back and someone will tell you what to test.
Old 05-04-2013, 06:06 PM   #17
I have one sitting right here next to me >Thank you very much. I thought this was a diy to help someone,that does not know how or what to do!!! Sorry for any inconvenience that I may have caused. I am sure someone else out there may be having the same problems, but are to afraid to ask.!!!!!!!!!
rickyjoseph701 is offline   Reply With Quote
Old 05-04-2013, 06:14 PM   #18
DIY staff
I'll offer a few suggestions---I suggest you pull the cover off of the breaker box and see if the breakers have power---
touch the probe to the colored wire attached to the breaker and the other probe to the box or the neutral bar (the one that the white wires are touching)---
No sence checking the outlets if the breaker has no power.
Old 05-04-2013, 06:17 PM   #19
jproffer's Avatar
Rewards Points: 716
Well that's a twist....it's hard to read "tone" in text, so maybe I'm reading more into that than I should be, but WOW.
Don't think anyone was inconvenienced. If we didn't want to be here, we wouldn't be.
jproffer is offline   Reply With Quote
The Following 2 Users Say Thank You to jproffer For This Useful Post:
jbfan (05-04-2013), MTN REMODEL LLC (05-06-2013)
Old 05-04-2013, 06:19 PM   #20
Either way , wouldn't I have to change the receptacle where it sparked and also why would I not have power to the breaker box before the spark and nothing after the spark when it happened at the receptacle????
Old 05-04-2013, 06:22 PM   #21
DIY staff
I'm not inconvenienced--just trying to help---
with electrical failure I always start at the source---one thing to remember---the outlet might have power but no neutral--so do not get careless ----
That is why you need a two wire tester----look for good power and neutral.
Old 05-04-2013, 06:30 PM   #22
Maybe I am dumb and stupid, but I can't see why it would spark at the outlet if there was no power at the box. I'm confused.Maybe I should leave it to professional help and pay them big bucks to do it . I'm disappointed.
To all who have given me information and tried to explain it to me I would like to say Thank You, and once again, I hope that I have not become a nuisance to your group and have not inconvenienced any in any fashion or matter.
Old 05-04-2013, 06:36 PM   #23
DIY staff
Disappointed in what?
Have you tested the breaker? You actually have two that control that out building---
the one in the out building and the one it is fed by in the house.
If you don't do the work while we analyze the results--then ,by all means, hire a pro to do the testing.
Here the pros are willing to help someone ready to follow directions.
Old 05-04-2013, 07:05 PM   #24
The wire that runs to the box also goes to the meter.If I have power ever place else, then I have power to the shed, is that right. Then the wire coming out of the box is going to the outlets of which there are 5. They were all working fine with power strips. I plugged in a drill to one of them and it stopped working. I unplugged everything and plugged it in and that is when the receptacle sparked and the power went out on all of the outlets. There is a ceiling light that is still working when I turn it on. That is why I am seeking help and assistance in this matter. The main box has 4 circuit breakers 1 is for the light, and the other 3 are not marked as to which one controls which outlet.
Old 05-04-2013, 07:27 PM   #25
DIY staff
I understand that---have you tested the breakers yet?
Have you tested all outlets for power and working neutral?
Old 05-04-2013, 07:30 PM   #26
Yes, I have checked all outlets and there is NO Power to them, I am not sure how to check for nuetral
Old 05-04-2013, 07:40 PM   #27
DIY staff
If no power is getting to the wires feeding the outlets--then see if power is at the breakers--
If they are all powered let us know.
Old 05-04-2013, 07:41 PM   #28
DIY staff
When you checked the outlets ,did you check the wires or insert the probes into the slots?
Old 05-04-2013, 07:43 PM   #29
If you are super moderator, go ahead and take me off this site, you are getting frustrated and so am I , I will figure it out some how, maybe professionall or I can go on with out any power in there.
Old 05-04-2013, 07:48 PM   #30
Both, I only checked the wires in the back of the outlet that sparked. I did insert the probes in to all of the other outlets. How do you check for working neutral?
GE Panel - Breakers - Tandem or Slim? TBrown1 Electrical 12 06-05-2012 07:42 PM
How can a buss have breakers not hot? James K Electrical 16 02-10-2012 04:14 PM
Duplex circuit breakers wavewuver Electrical 9 12-17-2011 10:12 AM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 10:19 PM
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 06:08 PM
