Dead Receptacle, Two Hot Wire Feed... Need Some Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 04:08 AM   #1
Dead receptacle, two hot wire feed... need some help
I just moved into a house and it has a dead receptacle. There's power coming into it. When I attach a prong to both it reads DC... weird I know. So I decided to run a extension cable to the receptacle to test it out. Here is a diagram of my findings. There is also two white wires attach to C and D that feeds to the outlet on the otherside of the wall.
mnsoda is offline   Reply With Quote
Old 07-12-2012, 04:42 AM   #2
Usually, when I find "two white wire" running between walls, it's because some one in the past has used a "zip-cord" to hook-up an additional outlet.
If this is so, then beware... Zip-cord is not rated for "permanent" use, and poses a code & safety violation.
(The probable reason why the outlet doesn't work, is because a competant electrician wouldn't use such means to wire an outlet).
(Note: In the electrical trade...using the "white" wire...or the "green" wire as a substitute for a phase wire (the "hot" wire)...is worse than a Mortal Sin... Why, it's simply --- cheesy!
kontoose is offline   Reply With Quote
Old 07-12-2012, 05:06 AM   #3
what will happen if two hot wire workin the same lamp
philip paha is offline   Reply With Quote
Old 07-12-2012, 07:19 AM   #4
Master Electrician
If they're on the same leg nothing will happen. It won't light up. If they're on different legs you'll get 240v on your lamp and the brightest 60w bulb you ever seen for about half a second.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-12-2012, 07:57 AM   #5
Rewards Points: 1,418
The dead receptacle probably has a loose neutral (the left wire in your diagram for the duplex receptacle),, which goes tot he side with the larger prong slot.
This could be either at the receptacle in question or at the last working receptacle in the daisy chain from the panel.
Old 07-13-2012, 01:12 AM   #6
or it'll blow the breaker...
Wire Gauge for 100 AMP Generator Feed jtreibick Electrical 14 08-27-2011 01:44 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
wire feed size for dble oven setup ? ? ? yes.itsconcrete Electrical 29 09-12-2008 10:11 PM
