Dead Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 07:55 PM   #1
dead outlets
I have 3 kitchen outlets and 1 bathroom outlet on same circuit. One day the whole circuit quit working. the only appliance going was the fridge. I checked the breaker(20amp). It wasnt blown. I reset it anyway. No luck. I have replaced all 4 outlets, none of the old ones showed any signs of burns or other issues. all were attached to screws. I also replaced the 20 amp circuit breaker. All are still dead. I would appreciate any suggestions.
thanks
mdmapes is offline   Reply With Quote
Old 06-26-2010, 08:00 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you have some means to check voltage?
and when was your house built?. Wiring as it is is against current National Electrical Codes.
Old 06-26-2010, 08:09 PM   #3
joed's Avatar
Rewards Points: 11,596
Look for a tipped GFCI in the garage.
Old 06-26-2010, 09:06 PM   #4
house is older. i have a voltmeter but dont know how 2 use it.
also garage is seperate circuit with no gfci's
Old 06-26-2010, 09:12 PM   #5
nap
You talking to me?
nap's Avatar
ok, what kind of voltmeter do you have?
are you comfortable being around live electricity such as having a receptacle hanging out of a wall while energized or checking the voltage on an energized breaker?
Old 06-27-2010, 08:40 AM   #6
Rewards Points: 1,418
A wire fracturing inside of its insulation is not unheard of. The wire ends exposed in the box can take only so much flexing as a switch or receptacle is replaced. You would need to be skilled in the use of a voltmeter and an ohmmeter (or continuity tester) to find such a break.
Old 06-27-2010, 02:30 PM   #7
Totally screwed together
Look under your sink for a GCFI for the wishwasher/ garbage disposal.
xxPaulCPxx is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Dead Outlets & Lights JnWaco Electrical 14 03-03-2009 12:08 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
