Dead Outlet, What Is Easiest Way To Trace?? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 01:03 PM   #1
walt1122
Rewards Points: 334
Dead outlet, what is easiest way to trace??
Hi all, outside outlet was working fine till yesterday. Today nothing!! so I:
1. Put in probe tester and no beep beep.
2. Tried the little three light tester you plug into the outlet and it shows no lights, legend on it says that means "open hot".
3. Removed outlet cover, removed outlet and not "hot" at screws. It is the end of a run so nothing after it.
4. It is a regular outlet although it says it is GFIC protected and I have tried all the GFIC's I can see including the ones in the service panel
4. None of the other lights, circuits acting up and I have turned off all the circuit breakers at the box and turned them back on.
Nothing seems to help.
So, any suggestions?
Wire is buried in wall and hard to trace.
Walt
walt1122 is offline   Reply With Quote
Old 08-29-2011, 01:08 PM   #2
if you have checked for tripped GFI somewhere near the dead outlet and didn't find anything you might have a bad connection in another box somewhere. could be a bad GFI. has any work been done recently in that area?
Old 08-29-2011, 01:19 PM   #3
Licensed electrician
Rewards Points: 1,626
I would guess you missed one GFI.
Old 08-29-2011, 01:48 PM   #4
Licensed Pro
Try the ones you can't see. Look behind things in the garage, other locations outside, in closets, bathroom, crawlspace.
Old 08-29-2011, 03:35 PM   #5
walt1122
Rewards Points: 334
Hi DannyT, no electrical work done for month.
Jim Port, possible but I looked everywhere in this small apartment and have not found any that are not working properly. PLUS, this is the end of a circuit! If there is a ground fault I missed wouldn't there be some thing else on this circuit that would be also not working along the way to this end outlet? It is a 20A so I'm guessing it is not a single circuit I'm not finding any other outlet/switch that is acting up and thinking I need to trace back to the box to see what circuit is acting up. If I can find out where the wire is coming from I should be able to check where the problem starts. I would rather not have to open every outlet/ switch to see where the problem lies. So do I have to do some kind of continuity to go from the white at the outlet back to the neutral bar at the service panel.
HouseHelper, you are probably right and I will keep looking but just suppose there is a problem how would I go about finding where the wire is coming from.
thanks
Walt
Old 08-29-2011, 03:51 PM   #6
i would check the boxes that the work was done in first.
Old 08-29-2011, 05:06 PM   #7
walt1122
Rewards Points: 334
thanks but, as I mentioned in the first post that was where I started and there is NO power on the black wire coming in. So it is dead at the screw where the outlet and box meet and I need to find some way to get to where ever the wire is coming from to see why there is no power. If everything I'm finding appears right then I wonder if there is just a lose wire a break or a defective ground fault that shows that it is working at the outlet but not sending voltage out to this outlet. It is that problem area that I wish to figure out how to find. Like those circuit checkers that you put on the line to trace back to the box what circuit it is in the box. I need something like that except I thought they are used on the black line and I believe there is a problem with the black line so it won't work in this case.
thanks
Walt
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 03:40 PM
Exterior 50 Amp RV Outlet theatretch85 Electrical 9 11-04-2009 11:07 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
