Dead Outlet : 120V Hot-ground, 0V Neutral-ground, 0V Hot-neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2014, 07:27 PM   #1
FPJ
Question
Dead outlet : 120V hot-ground, 0V neutral-ground, 0V hot-neutral
Hi,
I have 3 outlets that don't work. When I look with the multimeter for the voltage between hot and ground, I get 120V. When I check from neutral to ground, I get slightly above 0V. But when I check from hot to neutral, I get about 0V.
Any ideas as what the problem could be?
Thank you,
Frederic
FPJ is offline   Reply With Quote
Old 02-22-2014, 08:21 PM   #2
Rewards Points: 13,960
Loose neutral wire some place.
Could be anyplace, outlets panel box.
If the outlets are back stabbed redo them so there under the screws.
Old 02-22-2014, 08:43 PM   #3
Rewards Points: 512
Agree with Joe.
Find out how many receptacles are on that circuit, and check them all for loose white wires.
Installation is the Reverse of Removal.
Old 02-22-2014, 10:21 PM   #4
joed's Avatar
Rewards Points: 13,288
Move the black and white both to the screws if they are back stabbed.
Old 02-24-2014, 01:50 PM   #5
FPJ
Thank you, problem solved
Thank you for putting me on the right track, the problem is now fixed. It was indeed an outlet in another room on the same circuit that I didn't think of. However, it took me a little longer to find out as all wires were well screwed in.
It turned out that one outlet was defective with no continuity between the two screws on the neutral side.
Thanks,
Frederic
The Following User Says Thank You to FPJ For This Useful Post:
sirsparksalot (02-24-2014)
Old 02-24-2014, 04:26 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I've never seen a defective receptacle in that nature, do you still have it? Can you post a picture?
Old 02-24-2014, 04:29 PM   #7
Rewards Points: 366
i got a receptacle like that one time, like to drove me crazy. on looking at it you couldn't see the problem. but when you hooked it to power everything below it was dead, & it was brand new!
circuitman is online now   Reply With Quote
Old 02-24-2014, 04:32 PM   #8
E2 Electrician
I'm confused, how could you not see the tab broken out?
Old 02-24-2014, 05:58 PM   #9
Rewards Points: 366
that was the point of my post, you couldn't physically see it. that was also what puzzled me too. think the piece was a thin stamping.
Old 02-25-2014, 12:12 PM   #10
Rewards Points: 240
I would not think to check if a receptacle brand new from the store had the tabs broken off. But possibly some vandal went through the bin at the store and broke some of them off. Never would have thought of that, but the next time I buy a receptacle I'll check first.
fa_f3_20 is offline   Reply With Quote
Old 02-25-2014, 12:47 PM   #11
Rewards Points: 336
Are you sure that the "defective" outlet you replaced wasn't supposed to have a broken neutral tab? Was the hot tab still in place? I don't believe there's any reason for electrical wiring to have a hot tab in place but a neutral tab removed, but there are reasons to remove both tabs, or just the hot tab.
JKeefe is offline   Reply With Quote
Old 02-26-2014, 11:26 AM   #12
Rewards Points: 366
yeah! i'm postive,the outlet was brand new out of the box. i belive when they stamped the pieces, they cut them a little thin, so when current ran through it , it gave.you couldn't physically see it. had me stumped too.
Old 02-26-2014, 12:45 PM   #13
FPJ
Just like mentionned, the outlet looked intact just like the others. The outlet was not new however, it had been there for years. One day, something must have happened to break the metal link between the two screws and the problem came up.
Very puzzling indeed!
Old 02-27-2014, 04:08 AM   #14
dmxtothemax's Avatar
Rewards Points: 5,486
Originally Posted by FPJ View Post
Hi,
Thank you,
Frederic
Where exactily where these measurements taken ?
You clearly have an open neutral !
Stratigic measurements will reveal all !
But we need to know where you measured from ?
dmxtothemax is offline   Reply With Quote
Old 02-27-2014, 08:47 AM   #15
Rewards Points: 336
If you read the thread, dmxtothemax, you will see that there was in fact an open neutral, the OP found it, and the problem has been solved.
Tags
electrical outlet , ground , hot , neutral
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
Help if it's not too late!! Cyndi Electrical 255 10-10-2008 09:18 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
