Old 03-13-2012, 05:48 PM   #1
Hell of a fella
dead front gfci switch?
Hi all,
I have two outdoor receptacles that are wired into a junction box in the crawlspace under my house. They are actually ran into a spare bedroom's circuit...therefore not gfi protected. There is a switch above the access (indoors) to the crawlspace that powers these outlets and also light that runs off of the junction point also.
Would I be able to replace the switch with a dead front gfci switch to get these outlets protected. Would doing this be safe and up to code?
Would I be better off undoing all of the previous owner's work and putting these on a dedicated gfci circuit?
House was built in '87 and I am in the US.
DrumBum is offline   Reply With Quote
Old 03-13-2012, 06:02 PM   #2
Electrical Contractor
You can't use the dead front to turn the lights on and off.
A dead front allows you the chance to reset the gfci in a more convenient place.
You can keep the switch and just rewire the receptacles to the dead front, or just install a gfci receptacle.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-13-2012, 06:20 PM   #3
Hell of a fella
Simple enough...thanks!
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 10:14 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 08:46 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
