Dead End Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 10:42 AM   #1
Dead end wire
Have one wire in my ceiling that is not going to be used anymore, can I run it into a box, wire nut the ends, cap the box and bury it under the drywall?
Tboy is offline   Reply With Quote
Old 12-02-2011, 11:14 AM   #2
As long as the wire is disconnected at both ends
jmans8666 is offline   Reply With Quote
Old 12-02-2011, 11:24 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Can you get to it above the ceiling?
If so, then yes, otherwise the box has to remain accessible.
Old 12-02-2011, 11:28 AM   #4
I also have one box that was the main light for the kitchen, I now want to add 6-8 pot lights with the wire coming out of that box, can it be buried or do I need access to it as well?
Old 12-02-2011, 01:33 PM   #5
Any junction of live conductors needs to be made in an accessible junction box (accessible from attic is OK, if there is attic space over the ceiling). If the cable is abandoned and disconnected from both ends, it can be buried.
clashley is offline   Reply With Quote
Old 12-02-2011, 01:33 PM   #6
jproffer's Avatar
Rewards Points: 714
Any place in a cable (romex or whatever) where conductors are broken (and reconnected with wire-nuts, presumably...but regardless if they are reconnected or just left for dead) have to be accessible from somewhere....if you have an attic, flip the box over and cover it up there.
All that assumes the conductors are still connected to power. As said above, if they are disconnected and are truly "dead" then bury them and forget about them.
EDIT TO ADD: HAHAHA, I type too slow I guess
jproffer is online now   Reply With Quote
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
