Dead End 3 Way Extension - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 11:29 PM   #1
Lightbulb
dead end 3 way extension
I have an existing 3 way with power going to sw1, 14/2 going to light fixtures, and 14/3 going to other 3 way sw2. I find that I want to add a light fixture near sw2 to be controlled with the other lights in the 3 way.
The R and W wires are travelers and the B wire goes between the odd colored terminal screws (Point?). I was told that I could pull in another neutral wire into the sw2 box and extend it to new light fixture. I assume the neutral wire is desired to come from the same circuit. If all ok so far, does the light's W wire get wired to the new neutral and the lights B wire gets hooked to the point with the other black?
nitschke is offline   Reply With Quote
Old 12-11-2012, 11:32 PM   #2
joed's Avatar
Rewards Points: 11,608
You can not just pull in a neutral wire. The neutral must be in the same cable with the other wires. You must pull in a new cable or wire you new light fixture to one of the other fixtures.
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 10:38 PM
Dead Breaker? and Nusiance Tripping... jasonblu Electrical 9 11-06-2009 07:13 PM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 08:50 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 10:11 PM
