Dead Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 08:12 PM   #1
Dead circuit
WEll using the maicowavethe other day it died. found a few outlets and light also on same circuit dont work. no breakers tripped. i noticed well inspecting a outlet when you touch the ground to the nutral the circuit come alive. not sure what that means any help would be great if more info is needed i will do my best to give it
turboboost4me is offline   Reply With Quote
Old 05-28-2012, 08:17 PM   #2
Rewards Points: 6,652
Bad Neutral somewhere (ie came loose down the line). What you are doing right now, by touching ground & Neutral together is playing with fire.
Old 05-28-2012, 08:18 PM   #3
DIY staff
Rewards Points: 7,174
After you turn off the breaker---remove that outlet from the box and test the wires---tell us what you find--
Old 05-28-2012, 08:20 PM   #4
i was pushing the out let back in the wall and it touched. it only touched for a few secounds the i got it to not tuch i new enough to not let them touch
Old 05-28-2012, 08:23 PM   #5
Licensed electrician
Rewards Points: 1,774
The failed connection may be in the box you were playing with. A heavy load can cause the connection to fail.
If not in this box look upstream.
Old 05-28-2012, 08:24 PM   #6
IM having a hard time figuring out which breaker it is the box is labled poorly.
Old 05-28-2012, 08:40 PM   #7
DIY staff
You said that the tester lit up when you poke it into the neutral and ground?
If so--leave it lit and keep flipping breakers until the tester goes out--
Old 05-28-2012, 08:42 PM   #8
i just turned every breaker off and got the wife out of bed to help me. i found the breaker and i think i have a full list of what lights, rooms, and outlets are on it. looks like the hole circuit is not dead just half of it
Old 05-28-2012, 09:56 PM   #9
DIY staff
Likely you have a bad connection--could be an outlet that is used as a carry through has failed--
use the tester--could well be that the power is good and the neutral has gone bad--
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Drywall over 2 gang electrical box that has dead circuit? wbc Electrical 3 10-10-2011 08:29 AM
Circuit dead without tripping breaker? rpfeinman319 Electrical 3 03-20-2010 09:02 PM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 09:04 PM
