DC Rotary Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 03:40 PM   #1
DC Rotary Switch
Hello all, I am looking to find a simple rotary turn switch for DC current. The key is I want this switch to have three positions, on (positive and negative currents are connected to the output), off (currents are disconnected to the outputs) and inverted (positive and negative currents are connected to the outputs in opposite order of the on position). I know that there has to be something out there, I don't think I know what I need to be searching for. I would like to switch to be able to handle between 30 and 50 amps. Thanks
radarnasty is offline   Reply With Quote
Old 05-05-2011, 03:48 PM   #2
Mad Scientist
You need a DPDT (double pole double throw) rotary switch with center off position. You would wire your load to the common terminals, and power to the other terminals such that positive and negative are reversed depending on which way the switch is turned.
I don't specifically know where to find such a switch, but it sounds like the sort of thing that might be used in RVs and boats to switch between two batteries.
McSteve is offline   Reply With Quote
Old 05-05-2011, 04:17 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
A drum switch will work as well.
All the little carts we have at work have them, for forward, off and reverse.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Home lighting switch installation help needed ... Merk13 Electrical 14 12-29-2010 09:53 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
looking to replace a rotary switch Unregistered Electrical 1 03-31-2004 01:57 PM
