DC Cable Inwall - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 06:45 PM   #1
DC Cable inwall
I am looking at purchasing a Yamaha Musicast system.
in order to power the inwall client panels it comes with a 2 meter DC wire that screws into terminals on the back of the client box and then into terminals on the I/O box - fromt he I/O box is a plug.
What i need to do is expand the length of the DC cable - the 2 meters that it comes with is way to short and i wanted to locate the I/O box in a open closet.
Does anyone know what type of DC cable id need to run safley inwall?
thanks
badgerbrian1974 is offline   Reply With Quote
Old 02-18-2008, 07:41 PM   #2
Rewards Points: 6,652
You could probably go with "Bell Wire", which is used for Thermostats & Door Bells (also used in the past for Telephone's) for the extra length. As for the wire size, find out the gauge size of the wire that you have now, and that should help you determine the size to go with.
Old 02-19-2008, 10:09 AM   #3
I assume the bell wire just has to be the same gauge as the one that comes with the yamaha kit, and has to be inwall rated.
Bell wire is fine to carry DC voltage?
Sorry i am only used to running low voltage stuff like cat cable,coax etc.
Starting to try my hand with other stuff now.
Old 02-19-2008, 10:13 AM   #4
Any wire out there will carry a DC voltage. Even Lamp Cord that is two conductors. Now that I looked back, 2 meters is over 6' US. How far are we talking distance wise? Too long, you are talking a tripping hazard.
Old 02-19-2008, 10:48 AM   #5
Maximum distance from where the in wall client will be to the location of the I/O box is about 25ft
Old 02-22-2008, 02:44 PM   #6
Is 25ft going to be too long or am i fine with that ?
Old 02-22-2008, 02:54 PM   #7
Rewards Points: 2,350
What is the voltage and current of the panels? Voltage drop may be a factor if the voltage is small and the load is large, because 25 ft is nearly 4 times the distance of the 2 meter cable that came with the system.
You should probably find out what size the original cable is, then get some speaker cable one size larger. Make sure the cable is rated to be installed in a wall.
InPhase277
Old 02-26-2008, 01:55 PM   #8
Ok from what i could accertain -
DC Out to the inwall controller is
+12V GND +12V GND
DC in to the I/o Box (transformer) is 12v - which will be plugged directly into a standard socket.
DC IN
GND +12V
On the controller it only has one dc in and one grnd in.
So i need a cable to run about 25ft.
So 2 x25ft Speaker cable which can carry that voltage.
So what gauge would i need ?
thanks for the help
Old 02-26-2008, 08:58 PM   #9
+12V GND +12V GND
DC IN
GND +12V
thanks for the help
Voltage isn't what we are concerned with except for voltage drop. But voltage drop depends on current drawn. We need to know the amps. Any cable can handle 12 volts, you need a cable to handle the current.
InPhase277
Old 02-27-2008, 05:19 PM   #10
Thank you for your inquiry regarding Yamaha product. The power output of the power supply is 12 volts at 3.33 amps. I hope this helps and thank you again.
as per Yamaha
Old 02-27-2008, 05:52 PM   #11
as per Yamaha
If that is the max that the supply can deliver, then I guess you'd be OK with 16 gauge cable. You can go even smaller, but 16 is as small as I'd go. In fact, just being me, I'd use 14.
InPhase277
Old 02-27-2008, 06:51 PM   #12
cool il go with 14 then -
thanks for all your help
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
Projector Receiver cable TV box bigboyjoel Home Theater 4 12-19-2007 02:23 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 10:04 AM
CABLE for TV in basement DIY4EVER Electrical 5 06-19-2007 06:01 PM
