DC Adapter Voltage & MA Basic Info, Please - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 08:53 PM   #1
DC adapter Voltage & mA basic info, please
Hello, I have a desktop nightlight for my little girl that requires a "4.5V 50mA" DC adapter. I have found one in our "junk drawer" that is 4.5V, but says 250mA. Can I use that one, or will the extra 200mA damage the unit?
(I know nothing of electrical matters.) Thank you for whoever takes the time to respond. I appreciate it.
buyerpro is offline   Reply With Quote
Old 03-18-2012, 09:03 PM   #2
Rewards Points: 3,256
It should be fine. You can go larger on the amps but not smaller.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
buyerpro (03-18-2012)
Old 03-18-2012, 09:08 PM   #3
Thank you, Zappa, and what is the difference btwn "Voltage" and "amps" then? In layman's terms? Tracie
Old 03-18-2012, 09:17 PM   #4
Ummmmm....voltage would be like the water pressure in a garden hose and amps would be the flow, or gallons per minute.
Maybe someone else can come up with something easier to understand but I can't think of anything off the top of me head. An internet search could help also.
Old 03-18-2012, 09:30 PM   #5
In your case you don't want to go higher or lower with the volts because that is what the lamp wants to see or is rated for. It will only draw 50ma and the larger power supply will only deliver what the lamp is calling for and will be like in retirement mode just putzing along and very happy not having to work very hard.
Old 03-18-2012, 09:35 PM   #6
And what about Polarity?
Thanks so much for kindly taking your time to answer me, Zappa. In looking further, I have found that apparently I need to be very careful about "polarity." I know I can look on the appliance and see that it may say "DC", but how do I know if I have the polarity correct? I'm not really understanding what this final step is. Can you help? What notations am I looking for on both the adapter & the appliance to know if the adapter is compatible with the appliance in terms of polarity? Thanks again!
Old 03-18-2012, 09:40 PM   #7
There should be a black dot with an open circle around the black dot if you have the round popular connector I'm thinking of. There will be + and - pointing to the black dot and open circle. If both the power supply and the lamp match you should be good to go.
There are also a few different sizes (diameters) of connectors so that may be another problem if they don't match.
Old 03-18-2012, 10:09 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,604
Most things will have an polarity mark on them.
And also most power adaptors have a mark on them.
So it is good to look closely at each to be sure.
The most common is tip is positive.
dmxtothemax is offline   Reply With Quote
Voltage Problem H. Bruce Electrical 5 09-24-2010 12:14 PM
Reduced Voltage Supply to Outdoor Light mark2741 Electrical 6 09-05-2010 02:44 PM
DC voltage from a PCB dave11 Electrical 3 07-20-2010 06:13 PM
Need basic breaker info please honker Electrical 176 06-01-2008 10:10 AM
Need info on Basic Member Sizing etc. exup Building & Construction 3 01-18-2008 04:47 PM
