DC To AC Converter Load - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 09:37 PM   #1
DC to AC converter Load
Can a 1000 watt 2000 peak DC to AC inverter run 2 household sump pumps simultaneously? Hurricane is coming and I'm trying to get ready for power outage potential
Lozier711 is offline   Reply With Quote
Old 08-25-2011, 11:02 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,102
Unlikely I would say !
What is the power usage of the pump motors ?
It should say on the motors name plate ?
the main problem will be the starting current.
Whilst 1000w with 2000w peak might just run one pump,
depending the amp draw, and the load on the pump.
It is unlikely that it would run two.
If the amp draw is not too large, and the invertor
will run one pump ???
Then a second invertor could run the second pump,
again depending on the amp draw.
Have a look at the motors and find out there amp draw ?
You would be better off using a small gen set,
As gennys can tolerate short term overloads ( start up )
better then an electronic invertor will.
The overload circuit would shut down the invertor quick smart.
dmxtothemax is offline   Reply With Quote
Old 08-25-2011, 11:15 PM   #3
Rewards Points: 1,016
What will be the DC power source? If batteries, you will need a LOT of batteries to be of much good methinks due to the large load. Sounds like the job for a generator.
____________
Vince
Old 08-25-2011, 11:32 PM   #4
biggles's Avatar
whats the amp draw per pump ...and they are 115V?
Old 08-26-2011, 12:27 AM   #5
" Euro " electrician
frenchelectrican's Avatar
No I don't think so at all due most sump pump are 1/3 HP or larger you will have to find the nameplate or info if you can otherwise I know most common sump pump genrally use half horsepower motour which they will draw about 6 to 8 amp depending on pump itself.
The starting wattage will useally kill the inverter pretty fast and also with battery how big the battery you will have and they will draw a bit of current from the battery to the inverter { useally 10 to 1 ratio 12 amp @12 volts to 1 Amp @ 120 volts is typical but not always the case but close engough to figure it out quick }
As other poster mention the better choice for sump pump and fridge is use the generator they can handle the motour surge nice. { just watch the rating on the genrerators }
Merci,
Marc
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 11:14 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 12:49 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
