Dawn To Dusk Outdoor Light Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 07:59 PM   #1
Dusk to Dawn Outdoor Light Timer
Electrical Question about those Dusk-to-Dawn timers you can get for outdoor Christmas lights that turn on at night and turn off during the day, does anybody know if they only work if plugged into a 120V power supply? If it were rigged up to a 9 to 20 V power supply would it still function correctly?
jerevdl is offline   Reply With Quote
Old 12-02-2010, 08:11 PM   #2
Master Electrician
Rewards Points: 3,750
They are dusk to dawn not dawn to dusk and no, a 120 volt device will not work "rigged" up to 9 to 20 volt supply.
brric is offline   Reply With Quote
Old 12-02-2010, 08:18 PM   #3
Sorry yes I meant, Dusk-to-Dawn. I'm not asking if a 120V device will work with only 9 to 20 V, I know that obviously won't work.
What I'm asking is if I had, say a 10 V load and fed the 10 V supply through the Dusk-to-Dawn timer to the load, if the on/off function (Turning off when there is light, and turning on when there is no light) of the timer will still work.
Old 12-02-2010, 09:54 PM   #4
Master Electrician
Are you talking about a 10 volt load or a 10 amp load? A 120 volt photo cell could control a relay or contactor which could control a 10 volt device.
Old 12-02-2010, 10:20 PM   #5
Electrical Supplier
Rewards Points: 150
Those timers switch the voltage coming into them (3 or 4 wires, Black for hot, White for neutral and red for the switched load. Maybe a green for ground)
so no, they will NOT directly switch a low voltage load. However, you could have the timer switch a Relay or contactor that will switch whatever voltage you want.
You might look in to a Tork TU40
http://waterheatertimer.org/pdf/TU40-wiring.pdf
It will do 28VDC. Anything lower I think you will need to get into a relay system mate.
LyonsElecSupply is offline   Reply With Quote
Dusk to dawn sensor Plumbvoltage Electrical 3 12-06-2011 12:56 PM
DUSK TO DAWN LIGHT going on for 1/2 hour then off then back on. Jbl15666 Electrical 7 11-14-2010 01:47 AM
Troubleshoot Dusk to Dawn outdoor light marchem Electrical 7 09-05-2010 02:01 AM
Dusk till Dawn Light (Pole Light) Livewire78 Electrical 15 04-13-2010 08:53 AM
dusk to dawn light Pudge565 Electrical 5 09-27-2008 10:53 PM
