Old 10-10-2010, 11:17 PM   #1
data line runs, what rules from NEC?
so I'm running data lines (coax, cat5, audio etc) as I've mentioned in other threads and I got the NEC 2008 handbook (the more pages one) and it seems to be not specific about data lines. or at least the pages it points to talk about industrial settings, so, what are the rules on data lines and/or where can I find the pertinent ones?
many thanks
MLMIB is offline   Reply With Quote
Old 10-11-2010, 07:37 AM   #2
low voltage (like what you are doing) is not controled by the NEC.
When i do mine i still use the same rule of thumb for stapeling. However you can use the "low voltage" boxes (no backs on them)
baum is offline   Reply With Quote
Old 10-11-2010, 10:11 AM   #3
See Article 800 of the NEC.
Matsukaze is offline   Reply With Quote
Old 10-11-2010, 11:01 AM   #4
Do work
You shouldn't be stapling data cable. The cable should be supported, not stapled.
liquidvw is offline   Reply With Quote
Old 10-14-2010, 12:50 PM   #5
Some other handy tips when running low voltage (communication) wire.
You should not run communictaion wire through the same holes or right next to regular voltage wires(120/240).
Cross regular voltage wires at 90 degrees and i argee with liquid low volatge wire should not be stapled.
LazyC is offline   Reply With Quote
Old 10-14-2010, 01:17 PM   #6
Sorry i didnt mean with like a stapler.. i meant using a cable support of somesort (ie like the plastic hold downs that you use for romex with the nails)
Old 10-14-2010, 01:56 PM   #7
nap
You talking to me?
nap's Avatar
and why is stapling a problem? as long as you use the right staples and they are properly installed, I see no problem with stapling.
and do note the shoulders on those staples so they cannot be over driven onto the cable. The simple U shaped staples I would stay away from as those can easily be over driven and pinch the cable.
Questions regarding AC coil condensate line lassiter1979 HVAC 1 03-14-2010 09:47 PM
Installing a gas line, pre-planning ignition Plumbing 1 02-28-2010 06:01 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
GFI will not reset will line is hot soccerdude Electrical 15 09-07-2008 02:11 PM
