Damp Wet Location, Is Romex Or Metal Boxes OK - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 05:11 AM   #1
Rewards Points: 242
Damp Wet Location, Is Romex or Metal boxes OK
For a roof or pavillion covering say a backyard patio similar to the photo, would under the roof be considered a wet or damp location?
Am I correct that either way it is not OK to use romex stapled to the trusses to supply power to lights and or a fan?
But it would be OK to use UF feeder cable?
Also would it be OK to use metal boxes on the trusses?
collegetry is offline   Reply With Quote
Old 09-03-2013, 06:40 AM   #2
eastcoastsparky's Avatar
Rewards Points: 150
I would pipe it in EMT
eastcoastsparky is offline   Reply With Quote
Old 09-03-2013, 07:15 AM   #3
Rewards Points: 242
why would you pipe in EMT and use individual conductors over using UF cable?
Old 09-03-2013, 07:18 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I would use UF or PVC in both those out buildings.
Old 09-03-2013, 08:00 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
Metal boxes don't take long to start rusting when they are in a damp enviroment. The ones in my detached garage are starting to rust just from condensation that forms on them.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-03-2013, 10:45 AM   #6
Rewards Points: 2,512
I vote for PVC conduit.
hammerlane is offline   Reply With Quote
The Following 3 Users Say Thank You to hammerlane For This Useful Post:
mpoulton (09-09-2013), Philly Master (09-04-2013), stickboy1375 (09-09-2013)
Old 09-09-2013, 02:01 PM   #7
Rewards Points: 242
If I would want to hang a "ceiling" fan from an outdoor pavillion like hammer showed above, and metal boxes should not be used, what type of box would be used to hang a fan from the underside of the trusses?
Old 09-09-2013, 02:25 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,860
Here's a good option:
http://www.gordonelectricsupply.com/...FSVBQgodji4Adg
I definitely second the other opinions that PVC is the way to go. It is easier to work with than EMT, doesn't corrode, and is cheaper.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 09-09-2013, 02:30 PM   #9
Rewards Points: 242
A saddle box? Did not know such a thing was made. Thanks
Old 09-12-2013, 12:59 PM   #10
You can use a metal box to hang the fan. Paint it with rust inhibotor paint if you are concerned. Be sure to properly ground the metal box though.
Old 09-12-2013, 03:25 PM   #11
back to the original question if this is a wet or damp location, it is somewhat open to interpretation. the nec includes examples in the damp location definition which include 'partially protected locations under canopies'. but what does that really mean? imagine a receptacle at grade with the canopy directly above it but right in line with the roof edge. pretty obvious that even the slightest breeze while raining will direct water onto the receptacle. location would now be considered wet. but it is under the canopy so can't it be considered damp? a little common sense applies here. i've always used the rule of drawing an imaginary 45 degree line from the canopy edge inward and under the sheltered area. areas above the line would be considered damp, areas below the line would be considered wet. no actual basis in the code for this but presents a common sense approach.
regarding the romex (nm-b) question, nm is not permitted in wet or damp locations. by definition, the area under an outdoor canopy is a damp location and thus, nm-b is not allowed. even in conduit it would not be allowed as the interior of an outdoor, above-grade conduit is a damp location.
nothing in the code explicitly prohibits using the metal boxes under the canopy.
itsnotrequired is offline   Reply With Quote
Old 09-13-2013, 07:51 AM   #12
Post 11 has all your answers rolled into one.
Hole locations in metal electrical boxes miamicuse Electrical 1 08-18-2013 03:55 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 07:37 AM
Damp Location Definition Steve Burke Electrical 8 03-03-2011 10:58 AM
markers for location of junction boxes under insulation kelley4180 Electrical 14 01-24-2010 10:24 PM
4x4" juntion box in 'leaky' location - no cover or romex connectors culturalenigma Electrical 9 07-29-2009 07:43 AM
