Damp Location Definition - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 09:38 PM   #1
Can some one please help with the definition of a "DAMP LOCATIOn" as it applies to a bathroom. We have an enclosed shower and would like to put track lighting on a beam that is outside of the glass enclosure (but still in the bathroom), but the track is not rated for damp conditions.
Thank you. Steve
Steve Burke is offline   Reply With Quote
Old 03-02-2011, 09:48 PM   #2
Licensed electrician
Rewards Points: 1,234
Here is the NEC definition
Location, Damp.
Locations protected from weather and
not subject to saturation with water or other liquids but
subject to moderate degrees of moisture. Examples of such
locations include partially protected locations under canopies,
marquees, roofed open porches, and like locations,
and interior locations subject to moderate degrees of moisture,
such as some basements, some barns, and some coldstorage
warehouses.
You will need to meet the clearance requirements for fixtures above and near the tub zone. Here is a good diagram from Mike Holt.
Old 03-02-2011, 09:54 PM   #3
Master Electrician
Rewards Points: 3,746
Locations protected from weather and not subject to saturation with water or other liquids but subject to moderate degrees of moisture. Examples of such locations include partially protected locations under canopies, marquees, roofed open porches, and like locations, and interior locations subject to moderate degrees of moisture, such as some basements, some barns, and some cold-storage warehouse.
brric is online now   Reply With Quote
Old 03-03-2011, 08:52 AM   #4
Rewards Points: 1,558
Jim,
In the Mike Holt pic, I see (I think) a wall switch in the 3' zone of exclusion. So, this zone only pertains to lights and not switches (or outlets)?
Thanks,
Bob
bob22 is offline   Reply With Quote
Old 03-03-2011, 09:57 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Originally Posted by bob22 View Post
Jim,
Thanks,
Bob
Correct.
Switches and receptacles shall not be located within the shower/tub area, but CAN be in the "3 foot zone" outside the tub area.
Old 03-03-2011, 10:20 AM   #6
Originally Posted by Speedy Petey View Post
Correct.
everything is gfi protected yes?
The older I get the better I was
Old 03-03-2011, 10:38 AM   #7
No. Only receptacles.
Certain lighting IS allowed in the exclusion zone if GFI protected. Most recessed lights do not require GFI protection.
Old 03-03-2011, 10:56 AM   #8
been awhile for me but I thought any electrical you could reach while standing in a tub of water was protected, or is that just whirlpools? sorry for the ignorance
Old 03-03-2011, 10:58 AM   #9
No, not generally. There is no "touch potential" distance code.
Also depends on what you mean by "whilrpool".
Spas and pools have different rules.
The Following User Says Thank You to Speedy Petey For This Useful Post:
tpolk (03-03-2011)
Damp Insulation in Attic wiz561 Building & Construction 6 12-24-2010 12:16 AM
Encourage people to list their location secutanudu Site Help and Suggestions 0 09-15-2010 09:03 AM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 08:38 AM
Damp basement walls cjjjer Building & Construction 1 04-02-2010 05:18 PM
How do you build a 'damp OK' lamp? 1655graff Electrical 6 09-05-2009 11:29 PM
