Damp Location Cans - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 12:16 PM   #1
Rewards Points: 150
damp location cans
Would an "airtight" rated recessed remodel can light automatically be OK for a damp location such as over the tub or shower?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 06-10-2012, 12:58 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
As long as the water proof trim is used.
Coastal South Carolina
Old 06-11-2012, 03:43 PM   #3
Rewards Points: 150
Thank you, but my question is, does the airtight gasket also qualify as a damp location gasket?
Warren Zevon
Old 06-11-2012, 03:48 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Water proof? It only need be damp location rated, unless subject to shower spray, then a wet location trim is required...
IMO, i've never seen a shower head spray at the ceiling, so a damp location is all that is required.
Old 06-11-2012, 03:56 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
I fully agree.
Also, there is no such thing as a damp or wet location can. The trim is what makes that designation.
Speedy Petey is online now   Reply With Quote
Old 06-11-2012, 04:03 PM   #6
E2 Electrician
Originally Posted by Speedy Petey View Post
I fully agree.
Agreed, the funny thing is that a damp location trim is required where sheetrock is not even damp located rated, it just cracks me up to see a restriction of 3' zone for light fixtures around a tub/shower, yet have the building material not follow the same requirements.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Code05 (06-13-2012)
Old 06-13-2012, 12:59 PM   #7
Rewards Points: 150
that's great guys. You have all commented on rjniles response but near as I can tell I have not gotten a clear answer to my question.
Warren Zevon
Old 06-13-2012, 01:01 PM   #8
Licensed electrician
Rewards Points: 1,506
The answer was the housing are not damp or wet rated and do not need to be. It is the trim that has the damp or wet rating.
Whether it needs to be air-tight would be part of the energy code if adopted in your area.
Old 06-13-2012, 03:02 PM   #9
Then your reading comprehension skills need some work.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (06-13-2012)
Old 06-13-2012, 03:28 PM   #10
Rewards Points: 150
You can also have damp locations outside the 3' zone. OP probably doesn't want to know about GFCI, either. The reason they're different is so you can see through the debris after the ceiling collapses.
To clearly answer the OP question: No air-tight cans do NOT automatically meet the damp location requirements as spelled out in NEC, unless used with the proper damp location trim. Air-tight cans only prevent the air and moisture from migrating from the can to the uncondition space. By that time the electical components would have been comprimised.
goosebarry is offline   Reply With Quote
Old 06-13-2012, 03:40 PM   #11
Not necessarily. See post #5.
Old 06-13-2012, 11:02 PM   #12
Rewards Points: 150
My apologies. Yes the answer was provided and I somehow skimmed right over it.
Thank you for your patience
Warren Zevon
New IC rated recessed cans camner Electrical 8 05-21-2012 11:07 PM
Damp Location Definition Steve Burke Electrical 8 03-03-2011 09:58 AM
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
How do you build a 'damp OK' lamp? 1655graff Electrical 6 09-05-2009 10:29 PM
Junction box in patio ceiling I_think_I_conduit Electrical 6 08-20-2008 07:28 AM
