Damaged Wire, Help Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 11:51 PM   #1
Damaged wire, help needed
I was trying to install a new ceiling light fixture in our bedroom. When drilling a new hole to run the romex down to the light switch I nicked an existing wire. Can this be repaired or will the wire need to be replaced entirely?
The red insulation on that wire is damaged and if pulled back the copper wire is visible as seen in the link.
http://www.flickr.com/photos/93135998@N03/
Any help is greatly appreciated. Currently has electrical tape around red wire and around black wire on damaged places, and finally wrapped around the whole wire. I have power to this shut off at the breaker.
dcs6f4 is offline   Reply With Quote
Old 02-12-2013, 12:02 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My advice is to replace that wire. If the copper conductor wasn't nicked, then I'd say just tape it up, but with the damage done, you are risking that wire breaking.
Old 02-12-2013, 12:06 AM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would replace the wire and sleeve the area that got chewed with flexible conduit and anti short bushings.
I have seen some rats that chewed right through a copper conductor. They have tough teeth and can do a number on copper conductor.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 12:14 AM   #4
I will fix it, but is it unsafe to run power to this light in the meantime?
Old 02-12-2013, 12:32 AM   #5
k_buz's Avatar
Probably not, but that is no guarantee. If the wire happens to break, there could be some arching creating a fire hazard.
Old 02-12-2013, 01:13 AM   #6
" Euro " electrician
frenchelectrican's Avatar
I am on the same page as other guys mention the safest way you can deal is replace that cable with the same size as the oringal one which it got damaged.
It may be little tough to tug it due it may be allready stapled so I don't know how tight it will be so it kinda a risk to do more damage so go ahead and yank it out and fish in new cable.
But let me give you a head up before you start replaceing the cable make sure you marked all the connections goes before you take the switch box apart this part will really save your headache right there.
When you turn the circuit off double check to make sure this is off 100%
Bon Chance!
Merci,
Marc
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
wiring a whirlpool cooktop davidtyson Electrical 8 06-17-2012 01:58 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
