Damaged Nylon Sheath On THHN - Does It Matter? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 11:35 PM   #1
Damaged Nylon Sheath on THHN - does it matter?
Hi All,
After pulling some lengths of 3/0 and #3 copper cable, the wire coming out the final end of the conduit (wrestled past a couple LB's as well) the thin outer nylon sheath was torn in a few places. The underlying PVC insulation is in perfect shape without any abrasion whatsoever, so I do not have any strong concerns.
I know the outer sheath is intended to protect the cable and ease in pulling, but am wondering if it's removal where it has separated from the cable de-rates the insulation value at all?
Thanks!
raybo is offline   Reply With Quote
Old 10-07-2012, 11:51 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,902
I have always assumed that damage to the sheath is acceptable. Even new wire right off the spool often has defects in that layer, and it's so easily damaged it can't possibly be all that important.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-08-2012, 02:30 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
I agree with mpoulton....in fact, I have always looked at that sheath as the way of making the wire easier to pull.....it's really too thin to provide any type of protection and isolation....the underlying insulation does that.
damaged romex sheath bullhome Electrical 8 02-14-2012 01:34 AM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 12:41 PM
How to Strip the Sheath HooKooDooKu Electrical 17 01-28-2010 12:25 AM
