Dam squirrels
Hi, a squirrel crawled into a bathrroom exhaust vent and into the joist a joist space between my 1st and second floor. It ended up chewing on two lines of Romex running accross the space (perpendicular to the joists). It did expose the copper. I have a temp fix of using a "liquid electic tape". What are my choices for a permanent fix. I could follow each of the two run to both end to the junction boxes but that would require a bit of destruction. I couid cut out the damaged portion and used two junction boxes for each end of the cut but I would then need a access hole to them in the ceiling. This would not be very good looking. My understanding is that I can not bury the splice with junction box behind the dry wall ceiling. Thanks
Dam squirrels
Any chance the squirels hit the live and neutral at the same time, now that would make a really good story.
Part of your corrective action should necessarily involve a trip to the woods to do some squirrel hunting.
You're right, you cannot bury a splice. Also, there is no code compliant repair option for this chewed cable. Tracing the cable back to each end or installing two junction boxes are the only compliant repair options. The third option is to abandon these cables (by disconnecting them at both ends), and refeed whatever they went to by an alternate path with new cable. |
Obviously, you have been up to the site and made some repairs. How did you get there? Through the ceiling?
My understanding is that you cannot install a j-box where it would be inacessible (burried). The fact that you have access to the attic would allow you to install a pair of j-boxes to replace the damaged section. I just went through a similar situation but wait for mds reply, I'm no house sparky. |
| All times are GMT -4. The time now is 01:11 AM. |
