Daisy Chain Sub-Panels To Garage? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 02:16 PM   #1
Rewards Points: 89
Daisy Chain Sub-Panels to Garage?
In preparation for a basement finishing, I had my licensed electrician move my panel away from the service entrance. To meet code (distance from entrance to shutoff), he had to install a main shutoff outside, then run the cable to my 200 AMP relocated box (and which also has it's own main shutoff), and which I now understand is technically a sub-panel.
I want to install a 100 amp subpanel in my detached garage. To avoid digging up concrete where the service cable enters the house, it would be easier for me to run from the internal (sub)panel to the garage.
I plan to have a shutoff just before the 100 AMP sub-sub-panel in the detached garage.
What are the additional requirements for this setup? Do I need a grounding rod at the garage? There are no metal pipes/wires running to/from the garage/house.
thanks
toddmanqa
toddmanqa is offline   Reply With Quote
Old 08-04-2010, 02:20 PM   #2
Just call me Andrew
Rewards Points: 1,020
Yes, you need 2 (i think) grounding rods for a subpanel in a detached garage.
Andrew
secutanudu is offline   Reply With Quote
Old 08-04-2010, 04:24 PM   #3
The 2 grounding rods are required
4 wire feed required
If you buy a panel with a main breaker then no additional shut-off needed
Neutrals & grounds on seperate bar in the sub
Neutral bar not grounded to the case
Where are you located
Old 08-04-2010, 07:59 PM   #4
Rewards Points: 89
I'm in upstate NY.
Old 10-22-2010, 10:50 AM   #5
Rewards Points: 89
Follow-Up Question regarding wire and burial
The wire I have to run between the house and garage is 4 Wire AWG 2 AL Type Use 2. I was planning on using the the grey PVC conduit from the subpanel in the house, underground, then all the way to the sub-sub-panel in the Garage.
Is this acceptable?
Does the Type 2 have to be in the conduit underground?
Also, what size PVC pipe would I have to use for this?
Thanks!
Tags
chain , daisy , daisy chain , panel , subpanel
Garage Door Openers: Belt or Chain JPM General DIY Discussions 16 12-09-2010 02:58 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage door opener, Sagging chain Mommycandoit General DIY Discussions 4 02-22-2009 10:39 AM
What to use to lubricate garage door chain? JayBird General DIY Discussions 7 09-08-2007 06:09 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
