Daisy Chain Help! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 12:56 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
What are you measuring the voltage with?
jbfan is online now   Reply With Quote
Old 06-27-2011, 01:03 PM   #17
A multimeter
hoytman1018 is offline   Reply With Quote
Old 06-27-2011, 01:05 PM   #18
Licensed Pro
Check all your connections... from the panel on. You may have a loose connection that will let you read 120V on the meter, but not allow any significant current to flow.
Old 06-27-2011, 01:11 PM   #19
jbfan's Avatar
Rewards Points: 400
Originally Posted by hoytman1018 View Post
A multimeter
Test the meter in a receptacle to make sure it reads correctly.
A bad battery can give a false reading, so you want to make sure that is not a problem.
Old 06-27-2011, 01:15 PM   #20
rbj
sans AC
rbj is offline   Reply With Quote
Old 06-27-2011, 01:36 PM   #21
Master Electrician
Rewards Points: 3,822
Better send pictures of the panel/breaker, switch box and the fixtures.
brric is offline   Reply With Quote
Old 06-27-2011, 03:41 PM   #22
Rewards Points: 1,500
Reviewing the bidding:
You have power -- switch -- L1 -- L2 -- L3 -- L4 -- L5
You do not want to connect L5 directly all the way back to the switch.
Conenct all the ground wires together in each box.
cONNECT ALL THE WHITE WIRES TO EACH OTHER IN EACH BOX.
cONNECT ALL THE BLACK WIRES TO EACH OTHER IN ALL THE swithc BOXES.
You said you get 120 volst white to black in each box with the switch on? If this is so there is no reason why the lights should not work.
Are you getting 120 volts from the center tab to the socket shell in each fixture (with the lamp unscrewed)?
Flusher chain problems debd Plumbing 2 06-30-2011 02:05 PM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Daisy Chain Sub-Panels to Garage? toddmanqa Electrical 4 10-22-2010 10:50 AM
How to chain 20A receptacles? deko Electrical 26 10-16-2010 12:15 AM
Can I daisy chain off the main breaker box? bugmenot Electrical 14 04-09-2009 06:59 AM
