Daisy Chain Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 10:41 AM   #1
Daisy Chain help!
I have 5 light fixtures wired in a daisy chain. I have them wired using 12-2 romex from the breaker to the switch then to each light. So it is sw- L1-L2-L3-L4-L5. I have 120 volts at the switch and each box with the switch on. Now I can't figure out why the lights aren't working. I even broke the chain and just wired the first light still nothing. What am I missing? Thanks
hoytman1018 is offline   Reply With Quote
Old 06-27-2011, 10:49 AM   #2
rbj
Do you have a neutral W-W and phase leg BK-BK to the first light? Daisy chain may not be the appropriate word if the circuit from L5 does not return to the switch.
rbj is offline   Reply With Quote
Old 06-27-2011, 10:56 AM   #3
Yes Blk/Blk and Wht/wht, and I guess this is wired in parallel, not a true Daisy chain.
Old 06-27-2011, 11:04 AM   #4
rbj
So there must be something askew in the lighting hookup. Is there a bare grounding wire connected to the housing also?
Old 06-27-2011, 11:18 AM   #5
All of the grounds are grounded to each box at the same point. So I have a ground from the switch, ground that runs to the next light, and ground from the light fixture. All grounded together.
Old 06-27-2011, 11:27 AM   #6
rbj
Maybe the wiring from the switch needs looking at. All white wires at the switch will be connected in parallel with one white going to the first light leg along with the switched black wire in the same cable with matching w-w and bk-bk connection in the lamp wiring.
Old 06-27-2011, 11:38 AM   #7
I have the white neutral wires wire nutted at the switch. Black hot from the box wired at the bottom off position on the switch. Black to L1 wired on the top on position of the switch.
Old 06-27-2011, 11:49 AM   #8
rbj
You might test the first light for on-off control from switch to luminaire. If that does not work, then something in the circuit is open wired.
Old 06-27-2011, 11:52 AM   #9
rbj
Hoytman, I am not trying to be joking, but have you checked the light bulb? Or is this a fluorescent tube CFL type lamping?
Old 06-27-2011, 11:53 AM   #10
Master Electrician
Rewards Points: 3,820
Perhaps the breaker is off. Do the fixtures have light bulbs?
brric is offline   Reply With Quote
Old 06-27-2011, 11:55 AM   #11
I have wired just the first light up and still nothing.
Old 06-27-2011, 12:02 PM   #12
rbj
A nystery for sure if you tested hot on and off. There must be an open circuit in the luminaire pigtails.
Old 06-27-2011, 12:02 PM   #13
I have checked the bulbs they are good. Have tried 3 different switches, even wired directly without switch where when I flipped the breaker on lights should have lit up. The breaker must be good if I'm getting 120 volts to each light right. I'm stumped I've done several jobs like this with no problem. I'm lost at this point how do I have 120 volts at 5 lights and none of them work?
Old 06-27-2011, 12:04 PM   #14
rbj
One minute apart in same thinking.
Old 06-27-2011, 12:07 PM   #15
rbj
There is a possibility that you may have heated up the lights with a parallel phase leg hooked up at the panel and there will be a 120V reading to ground.
Flusher chain problems debd Plumbing 2 06-30-2011 02:05 PM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Daisy Chain Sub-Panels to Garage? toddmanqa Electrical 4 10-22-2010 10:50 AM
How to chain 20A receptacles? deko Electrical 26 10-16-2010 12:15 AM
Can I daisy chain off the main breaker box? bugmenot Electrical 14 04-09-2009 06:59 AM
