Daisy Chain Extension Cords To Flood Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 07:24 AM   #1
Daisy Chain Extension Cords to Flood Lights?
Hi Everyone.
I need to place some external flood lights approximately 100meters away from a mains outlet (240V plug socket in my shed).
The flood lights are 4x 500Watt lamps. Will it be ok to daisy chain 2 or 3 extension cords (made from 3 core 1.5mm flex)? It will be a temporary solution used for no longer than an hour at a time and only in fine weather.
I've heard of voltage drop off and over-heating etc but cannot find a definitive answer if will be safe to rigg up what ive suggested above.
MrPickers is offline   Reply With Quote
Old 09-17-2013, 08:16 AM   #2
you're going to have voltage drop issues, more than 5%. this assumes copper conductors. if they are simple incandescent lamps, they will simply be dimmer than if you didn't have the drop. it isn't 'unsafe' per se but if you can get some bigger cord, go for it.
i wouldn't run motors or similar with that cord at that distance.
itsnotrequired is offline   Reply With Quote
Old 09-17-2013, 10:44 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,362
Originally Posted by MrPickers View Post
Hi Everyone.
I.5mm cable is usually good for 15a.
If your load is 2000w at 240v thats 8.8a,
Should be ok.
There will be a small loss of voltage,
but with incandesant lights they will still work ok.
most people would not even notice the difference.
But the thicker the cable the less loss.
dmxtothemax is offline   Reply With Quote
Yellow Jacket Extension Cords mobiledynamics Tools 2 11-01-2012 07:56 PM
RV extension cords rjniles Electrical 4 08-11-2012 08:59 PM
Exterior fan/light box to flood lights Kelly Durfey Electrical 3 11-23-2008 02:30 PM
Motion AND switch activated outside flood lights? rbbarker Electrical 3 06-18-2008 06:20 PM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 10:11 PM
