Old 06-12-2012, 01:31 PM   #1
Question
Cutting Wires
Would it be possible to cut a wire at an angle over a length of 2-3''?
If so, what tool (if there is one out there) should I use?
Is there some sort of jig that does this already?
Climax88 is offline   Reply With Quote
Old 06-12-2012, 01:40 PM   #2
Electrical Contractor
Cutting Wires
What size wire?
You could use a miter box and a hack saw, but the will be time consuming and will not produce the same results everytime.
What are you trying to do?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-12-2012, 01:40 PM   #3
Super Moderator
Cutting Wires
What are you trying to do? How thick is the wire?
Old 06-12-2012, 02:48 PM   #4
Lic Electrical Inspector
electures's Avatar
Cutting Wires
Band saw.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 06-12-2012, 03:00 PM   #5
Licensed electrician
Cutting Wires
The wire is going to need considerable thickness to allow the taper to be cut. Smaller conductors like a #12 it is not going to happen. You might be able to taper a 4/0.
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 09:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 01:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
