-   -   Cutting Wires (http://www.diychatroom.com/f18/cutting-wires-146821/)
Climax88 06-12-2012 12:31 PM
Cutting Wires
Would it be possible to cut a wire at an angle over a length of 2-3''?
If so, what tool (if there is one out there) should I use?
Is there some sort of jig that does this already?
jbfan 06-12-2012 12:40 PM
What size wire?
You could use a miter box and a hack saw, but the will be time consuming and will not produce the same results everytime.
What are you trying to do?
oh'mike 06-12-2012 12:40 PM
What are you trying to do? How thick is the wire?
electures 06-12-2012 01:48 PM
Band saw.
Jim Port 06-12-2012 02:00 PM
The wire is going to need considerable thickness to allow the taper to be cut. Smaller conductors like a #12 it is not going to happen. You might be able to taper a 4/0.
