Cutting Through Drywall Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 09:12 PM   #1
Cutting through Drywall Ceiling
Hello,
I am installing can lights in the kitchen and need to cut a strip of drywall out for the wiring. The strip will be about 12' long and 10" wide. Has anyone used a circular saw set to a 5/8" cut depth to do this? I am afraid to use a drywall saw as I may cut into something. Thanks.
BloodyKnuckles
BloodyNnuckles is offline   Reply With Quote
Old 10-12-2012, 09:17 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
A circular saw will make a huge mess...for days. The dust will get into the heating system and will be a problem for a couple days. I would use a straight edge and a razor knife, then break out the drywall.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
DangerMouse (10-13-2012), Missouri Bound (10-12-2012)
Old 10-12-2012, 09:26 PM   #3
Rewards Points: 12,882
A 10" wide slot to run a wire
A ciruler saw to cut sheetrock, never!
Something very wrong if it needs to be that wide.
Tell us more why your doing it his way.
Is this a first floor in a two story house?
Old 10-12-2012, 09:37 PM   #4
DIY staff
Rewards Points: 7,174
Investing in an inexpensive multi tool with a half round blade will make for a neat cut---but answer Joes question first---why the slot cut?
Old 10-12-2012, 09:44 PM   #5
Licensed electrician
Rewards Points: 1,054
Sounds like the wiring needs to go perpendicular to the framing. The slot allows a drill to get into the bays to drill.
Old 10-12-2012, 09:50 PM   #6
DIY Enthusiast
sublime2's Avatar
Hit the nail on the head with that one I'd bet!
sublime2 is offline   Reply With Quote
Old 10-12-2012, 09:53 PM   #7
I have flexable drill bits up to 6' long for this type of work.
A whole lot less mess.
Old 10-12-2012, 09:59 PM   #8
DIY Enthusiast
sublime2's Avatar
Understandable as a contractor.
But the regular diy homeowner isn't going to have a tool like that available.
Old 10-12-2012, 10:15 PM   #9
Any Lowes, Home Depot, electrical supply has them.
Old 10-12-2012, 10:58 PM   #10
Thanks for the quick replies
Jim Port is correct. The wiring is perpendicular to the ceiling joists. It is also a two story home. I was thinking if the drywall was 10" in width, the drywall patch would be eaiser to handle. Also, the 10" width would give me plenty of room to work in.
oh'mike, are you talking about something like a rotozip (sp) that has a sheild that covers half the blade. I have an old rotozip that uses a drill bit looking tool. I use it for cutting circles and such. I will have to see if I can get an attachment. I was hoping to get something I could attach a shop vac to. Thanks.
BloodyNnuckles
Old 10-12-2012, 11:04 PM   #11
He's talking about a tool like this.
http://www.northerntool.com/shop/too...ilating%2Btool
Look at the top left. A whole lot less dust then a Roto Zip.
Old 10-12-2012, 11:05 PM   #12
MT Stringer's Avatar
Rewards Points: 218
This should do the job for ya.
http://www.harborfreight.com/power-t...amp-68861.html
MT Stringer is online now   Reply With Quote
Old 10-12-2012, 11:33 PM   #13
Neat Tool
joecaption and MT Stringer, Thanks for the links. I have seen these at Lowe's but never paid any attention to them. I will see if I can find a youtube video showing it cutting drywall. It looks like it might just be the ticket. Thanks to all that replied.
Best Regards,
BloodyNnuckles
Old 10-13-2012, 08:12 AM   #14
It's one of the most usefull tools I own, I have 2, or the Rockwell multi crafters and love them.
It goes through drywall like hot butter and has hundereds of other uses.
It would be far more accurite and at least 10 times faster then a razer knife.
Old 10-13-2012, 01:02 PM   #15
Rewards Points: 218
The Harbor freight model comes with a blade that resembles a half moon. It oscillates back and forth, thus cutting your drywall. A helper with a shop vac would help reduce the dust. You would be done in no time.
Good luck.
Mike
The Following User Says Thank You to MT Stringer For This Useful Post:
oh'mike (10-13-2012)
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 09:15 AM
Best way to install drywall on uneven ceiling Fred_ Drywall & Plaster 7 11-28-2011 09:54 PM
How much cellulose can a drywall ceiling support ? Arky217 Building & Construction 10 10-29-2011 10:48 PM
Building a 2nd Ceiling using 2x4's and Drywall cwk36 Remodeling 1 10-27-2011 09:58 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
