Cutting Off Grd Pin On TV Plug? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2007, 04:15 PM   #1
cutting off grd pin on TV plug?
For reasons that I don't understand our new Comcast TV convertor boxes have an ordinary power plug with three prongs, but the "switched" outlet has only two. So, a TV set plugged into the convertor can have only the two prong variety, but our TV sets have three prongs, with the ground.
It makes no sense to cut off the grd prong, but it's impossible to connect the TV to the convertor without cutting it off. The access is too tight to allow a 3 to 2 adaptor. We prefer to have the one remote turn on both TV and cable at the same time, ergo, using the switched outlet.
thanks
bob
robertpri is offline   Reply With Quote
Old 12-25-2007, 06:28 PM   #2
Rewards Points: 1,506
Use an extension cord (plug the 3 to 2 prong adapter into the far end of the extension cord.
Make sure that the cable box can handle the wattage required by the TV. This rating should be printed next to the convenience receptacle on the back of the cable box.
Old 12-25-2007, 07:07 PM   #3
ICF Construction
I've got a comcast box as well, the outlet on mine is not for turning the TV on or off, simply an extra outlet since the cable box is using one up in the wall. My remote turns the TV and cable box on independently. Try plugging the TV into a regular outlet and see if it works.
Chris
Chris Johnson is offline   Reply With Quote
Old 12-25-2007, 08:45 PM   #4
Chris, I think you have it right. In previous models, one could piggy back the TV to the convertor, but this one is different. I had to use both remotes to get them working, but now realize the remote is probably not programmed right.
Old 12-26-2007, 02:30 PM   #5
Rewards Points: 6,652
If the set is a high end HDTV, cutting off the Ground, will actually cause problems. You should have everything plugged into a Surge Protector, or even purchase something like this http://www.bestbuy.com/site/olspage....=1186003259724 to protect your electronics. Even better, invest in a UPS system to protect. Never just connect to a unprotected outlet, or cut off the Ground pins.
Old 12-27-2007, 07:52 AM   #6
Homeowner w/ aspirations.
While a decent surge protector might be a good idea (and don't cut off the ground pin, it's there for a reason), you absolutely do not need a $700 power conditioner. Unless you're getting extreme line interference (and you'd know it if you were), power conditioning is not going to give you a better picture, clearer sound, wash your car, make dinner, or any of the other fantastic claims some people might try to sell you. It's a bunch snake oil meant to squeeze more money out of the high-end A/V crowd, much like the gold plated outlets that folks like to poke fun at, around here.
MattOverMinder is offline   Reply With Quote
Old 12-27-2007, 11:08 AM   #7
The converter box's setup menu allows you to specify/change how the piggyback outlet behaves, i.e always "on" or converter-dependent as to "on" or "off".
End Grain is offline   Reply With Quote
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
Plug Sockets - Basic Question chris_stfc Electrical 6 12-25-2007 04:03 PM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 07:09 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
