Cutting Live RG6 To Install Splitter - OK? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 04:06 PM   #1
Rewards Points: 262
Cutting live RG6 to install splitter - OK?
I have a length of RG6 coax cable that I want to cut in order to install a 3 way digital splitter. The computers and the TV's are currently connected to this cable. Can I simply cut into it? I can't really shut it off, as I would a normal electrical circuit, right? Thanks.
tpagel is offline   Reply With Quote
Old 10-17-2012, 04:13 PM   #2
Licensed electrician
Rewards Points: 1,242
There should be a connection either just inside or outside of the house.
Old 10-17-2012, 08:02 PM   #3
Rewards Points: 243
It's low voltage, so there is no concern for electrocution assuming everything is hooked up properly. Jim is right there is probably already a splitter in the house somewhere you can hook a new cable into. I assume you have the tools to attach new RG6 connectors if you do cut into this cable. You can't use wire nuts.
chemman is offline   Reply With Quote
Old 10-17-2012, 08:16 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Here is a little video on what is involved....
ddawg16 is online now   Reply With Quote
Old 10-17-2012, 09:30 PM   #5
Rewards Points: 262
Thanks for the replies, guys. For better or worse, I did just cut into the cable (before I saw the replies here), knowing that it was low voltage, and that I wasn't in any real danger. I just didn't know if it would hurt the connections. I got everything all squared away (I had watched some youtube videos and knew I needed special tools, which I bought.) Everything is working fine. My only problem is that I thought I would be able to fit a "one line in-three lines out" digital splitter within a standard single low voltage box with a blank face plate. But with the radii of all the cables, I can't seem to make it work. Is there a trick? I don't really have room for a larger box within the framing, so I will need to look at it more closely tomorrow. At least I still have cable internet connection, so i can ask for help if I need it!
Old 10-17-2012, 09:48 PM   #6
Can you put the splitter outside the wall?
Old 10-18-2012, 12:13 AM   #7
Rewards Points: 150
Originally Posted by tpagel View Post
... My only problem is that I thought I would be able to fit a "one line in-three lines out" digital splitter within a standard single low voltage box with a blank face plate. But with the radii of all the cables, I can't seem to make it work. Is there a trick? I don't really have room for a larger box within the framing, so I will need to look at it more closely tomorrow. At least I still have cable internet connection, so i can ask for help if I need it!
There are 90 degree F-connectors that might help fit everything in the box; you should be able to get these at Radio Shack.
Or, depending on how you have the splitter arranged, you could bring the cables in from the top or back of the box, so it's a straight shot instead of having to make the bend. You might have to drill new holes in the box, not sure if that's allowed per code. Actually, I don't know if the NEC applies to millivolt level wiring or not.
Dave632 is offline   Reply With Quote
Old 10-18-2012, 07:42 AM   #8
Rewards Points: 262
I can't put the splitter on the outside, because then the cables would go back into the wall to go to other rooms, and that might look a bit odd. I will search for the F connector. My other option, I guess, is placing the splitter in the wall cavity, and just use the box and plate for access to it, although it would be difficult access. I will also see if I can cut some wood out of the way and fit a double box, though I am not sure the splitter would fit in that either. thanks for the replies.
Old 10-18-2012, 09:00 AM   #9
Rewards Points: 150
Another possibility is to drill holes in the box, and mount the splitter to the inside of the box, using nuts on the female F fittings of the splitter. Then only one of your RG6 cables has to make a 90 degree bend. You might have to hunt a bit to find the right size nuts.
Old 10-18-2012, 09:26 AM   #10
Rewards Points: 262
Thanks Dave. I will see if that would work.
Old 10-18-2012, 09:47 AM   #11
You do not need a box for the cable.
Old 10-18-2012, 10:04 AM   #12
Rewards Points: 262
Jim... Really? I can just put the splitter in the wall, close it up and and forget about it?
Old 10-18-2012, 10:28 AM   #13
Licensed Pro
Cut the back out of the box, attach the box to the wall, add a blank cover. All the room you need and you still have access.
The Following User Says Thank You to HouseHelper For This Useful Post:
zappa (10-18-2012)
HRV Install and balancing questions creamaster HVAC 0 10-07-2010 01:26 PM
Skylight Install - Cutting attic joist crossbeams? spup345 Building & Construction 1 08-26-2010 11:41 AM
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 08:56 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
