-   -   Cutting live RG6 to install splitter - OK? (http://www.diychatroom.com/f18/cutting-live-rg6-install-splitter-ok-160390/)
tpagel 10-17-2012 03:06 PM
I have a length of RG6 coax cable that I want to cut in order to install a 3 way digital splitter. The computers and the TV's are currently connected to this cable. Can I simply cut into it? I can't really shut it off, as I would a normal electrical circuit, right? Thanks.
Jim Port 10-17-2012 03:13 PM
There should be a connection either just inside or outside of the house.
chemman 10-17-2012 07:02 PM
It's low voltage, so there is no concern for electrocution assuming everything is hooked up properly. Jim is right there is probably already a splitter in the house somewhere you can hook a new cable into. I assume you have the tools to attach new RG6 connectors if you do cut into this cable. You can't use wire nuts.:no:
ddawg16 10-17-2012 07:16 PM
Here is a little video on what is involved....
http://www.youtube.com/watch?v=ZT6oEL7_bDs
tpagel 10-17-2012 08:30 PM
Thanks for the replies, guys. For better or worse, I did just cut into the cable (before I saw the replies here), knowing that it was low voltage, and that I wasn't in any real danger. I just didn't know if it would hurt the connections. I got everything all squared away (I had watched some youtube videos and knew I needed special tools, which I bought.) Everything is working fine. My only problem is that I thought I would be able to fit a "one line in-three lines out" digital splitter within a standard single low voltage box with a blank face plate. But with the radii of all the cables, I can't seem to make it work. Is there a trick? I don't really have room for a larger box within the framing, so I will need to look at it more closely tomorrow. At least I still have cable internet connection, so i can ask for help if I need it! ;)
Jim Port 10-17-2012 08:48 PM
Can you put the splitter outside the wall?
Dave632 10-17-2012 11:13 PM
Originally Posted by tpagel (Post 1032965)
... My only problem is that I thought I would be able to fit a "one line in-three lines out" digital splitter within a standard single low voltage box with a blank face plate. But with the radii of all the cables, I can't seem to make it work. Is there a trick? I don't really have room for a larger box within the framing, so I will need to look at it more closely tomorrow. At least I still have cable internet connection, so i can ask for help if I need it! ;)
There are 90 degree F-connectors that might help fit everything in the box; you should be able to get these at Radio Shack.
Or, depending on how you have the splitter arranged, you could bring the cables in from the top or back of the box, so it's a straight shot instead of having to make the bend. You might have to drill new holes in the box, not sure if that's allowed per code. Actually, I don't know if the NEC applies to millivolt level wiring or not.
tpagel 10-18-2012 06:42 AM
I can't put the splitter on the outside, because then the cables would go back into the wall to go to other rooms, and that might look a bit odd. I will search for the F connector. My other option, I guess, is placing the splitter in the wall cavity, and just use the box and plate for access to it, although it would be difficult access. I will also see if I can cut some wood out of the way and fit a double box, though I am not sure the splitter would fit in that either. thanks for the replies.
Dave632 10-18-2012 08:00 AM
1 Attachment(s)
Another possibility is to drill holes in the box, and mount the splitter to the inside of the box, using nuts on the female F fittings of the splitter. Then only one of your RG6 cables has to make a 90 degree bend. You might have to hunt a bit to find the right size nuts.
tpagel 10-18-2012 08:26 AM
Thanks Dave. I will see if that would work.
Jim Port 10-18-2012 08:47 AM
You do not need a box for the cable.
tpagel 10-18-2012 09:04 AM
Jim... Really? I can just put the splitter in the wall, close it up and and forget about it?
HouseHelper 10-18-2012 09:28 AM
Cut the back out of the box, attach the box to the wall, add a blank cover. All the room you need and you still have access.
