Cutting Holes In Plastic J-Box - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 05:58 PM   #16
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by InPhase277 View Post
Not worth the box they are in, in my opinion. The set 220 posted is good, as are the greenlee KO sets, but the general hole saws are worthless. If you want a good hole saw, go with Lennox.
Thanks much for the warning on those. I did want some of the larger hole saws for plumbing, which made that set especially attractive.
I've seen the lennox, I'll pick up a couple of those in the sizes I need.
Jamie
(will post photos shortly in a new thread of this afternoons project)
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 05:56 AM
foundation weep holes for drainage shama144 Building & Construction 12 12-31-2011 11:17 AM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 10:41 AM
Vent pipe boots -holes eaten in them N. Duval Roofing/Siding 3 02-03-2009 07:52 PM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 07:24 AM
