Cutting Flex - Electrical - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 10:40 AM   #1
Rewards Points: 288
Cutting Flex
What's the best way on cutting 1/2 and 3/4 Flex Metal.
I'm doing ~okay~ with a hacksaw. Might just grab the grinder....
mobiledynamics is online now   Reply With Quote
Old 12-26-2012, 10:52 AM   #2
add about 8 inches to how much you need and cut it completely. then take the flex and bend it hard at the legth you need to go in the connector. it will seperate itself a little. take your dykes(snips) and cut the flex where it has became a single strip. with the dykes push the jagged edge back in line with the rest of the flex. use the little red wire protectors that came with the flex and push into connector.
buddy builder is offline   Reply With Quote
Old 12-26-2012, 10:53 AM   #3
Rewards Points: 13,712
http://www.greenlee.com/products/CUT...cBX-CABLE.html
A hack saw or grinder is going to leave burrs.
You are using a plastic insert, right?
Old 12-26-2012, 10:55 AM   #4
the above advice is for flex containing wire in it. if it doesn't contain wire i use my bandsaw.
Old 12-26-2012, 10:55 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
That^^^^
Me being the cheap ba$tard I am, I hate wasting material....so I cut it once to length using a sawzall....
But as buddy noted....make sure you use the red wire protectors....otherwise your going to be replacing wire when you don't want to....
Old 12-26-2012, 11:17 AM   #6
Rewards Points: 288
The size of 1/2 + will not fit a roto split....
Bushing everytime. Who doesn't use a bushing..
Old 12-26-2012, 12:00 PM   #7
TTW
TTW's Avatar
If you have a bunch of cuts to do, grab a cutter, avail at BORG, and other big boxes, and hardware stores.
If this MC doesn't have wire in it already, get out the cutting torch!
Always use bushings (red heads)
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-26-2012, 12:03 PM   #8
Rewards Points: 288
Nevermind. Found a cutter that will handle 1/2 and 3/4 FLEX....
It's a much bigger beast than the normal BX roto split ya'll are thinking...
Old 12-26-2012, 05:20 PM   #9
Master Electrician
Rewards Points: 3,870
MC always contains conductors.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
jbfan (12-26-2012)
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 04:35 PM
sediment trap with gas flex line? diggerdave Plumbing 10 02-11-2009 06:14 PM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 08:07 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 01:12 PM
