Cutting 8/32 Bolts - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 04:31 PM   #1
Rewards Points: 278
Cutting 8/32 bolts
I seem to recall some wire strippers have a little hole, is that for cutting 8/32 bolts shorter. Does that produce a good cut and not going to cross thread anything?
DIYGST is offline   Reply With Quote
Old 01-11-2010, 04:34 PM   #2
Yes, just don't do what I did; cut off 3/32" from the wrong side, so I couldn't get the cut off piece out of the tool. Ever.
Old 01-11-2010, 04:45 PM   #3
Thread a nut onto the screw before cutting if you can, then when you remove the nut, it will fix the threads!
Billy_Bob is offline   Reply With Quote
Old 01-12-2010, 01:21 PM   #4
Rewards Points: 1,494
Round off the cut end of the bolt, just one or two threads' worth, using a file.
Old 01-12-2010, 01:28 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
This is what i do, works like a dream
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-12-2010, 04:44 PM   #6
Just thread it in, the tool tells you which side. Then after you cut, thread it in some more then back it out to fix the threads.
randrx2 is offline   Reply With Quote
Old 01-12-2010, 05:03 PM   #7
Make sure after cutting you realign the holes up before backing out the screw.
SULTINI is offline   Reply With Quote
Old 01-12-2010, 05:37 PM   #8
Yoyizit, thanks for throwing that out there,, I did the same thing last week but to make matters some what worse, I didn't realize why until reading your post. I'll probably never be able to shorten a screw that size again with my strippers but I got that piece out of there.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-20-2010, 05:01 PM   #9
Rewards Points: 278
Thanks, I did it, but it doesn't want to thread until I file down the tip all around.
The cut off wheel is a little faster but not as precise where I cut
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Leaking tank bolts splinters Plumbing 4 12-25-2009 06:04 PM
Leaking tank-to-bowl bolts on toilet MI-Roger Plumbing 8 10-18-2009 08:29 AM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 09:53 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
