Cutler-Hammer Type CC - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 05:54 PM   #1
Have a Cutler-Hammer Type CC
Amperes 200
2 pole unit.
Want to put in a few new breakers to run lights and outlets.
How do I know what type and size will work with this breaker box?
I know I want 15 amps based on the wires that is run (14/2 wire)
sdspears is offline   Reply With Quote
Old 05-22-2013, 07:56 PM   #2
Rewards Points: 13,968
The style you need should be right on the breakers you have now.
Old 05-22-2013, 08:54 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,348
Or read the manufactures specs, on that piece of paper pasted to your panel dead front. C/H should be available in every big-box in town. Eaton and Murray probably fit... but just get the manufacturer spec.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-22-2013, 08:58 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Not if it is type CH which I THINK it is judging by the main breaker style.
Old 05-22-2013, 09:08 PM   #5
K Buzz... I'm willing to bet you on that......
that you are right.
Peter
Old 05-24-2013, 07:34 AM   #6
It says Class CTL Type CH
120/240 VAC
Cutler-Hammer
AL-CU
When I looked up 15 amp "CH" on Home Depot says it's for use with heating, air-conditioning and refrigeration-equipment applications. ??? Is this correct?
Old 05-24-2013, 07:35 AM   #7
How do I get the manufacturer specs to know what fits?
Old 05-24-2013, 08:03 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 544
120/240 VAC
Cutler-Hammer
AL-CU
That will work.
jbfan is online now   Reply With Quote
Old 05-24-2013, 08:26 AM   #9
120/240 VAC
Cutler-Hammer
AL-CU
And we plan to use it for outlets and also one for 4 canned lights.
Old 05-24-2013, 08:51 AM   #10
120/240 VAC
Cutler-Hammer
AL-CU
SD.... CAVEAT... I'm a GC... not a sparky.... but I think (operative word think, not know) :
From what you say and read at HD, I think the Cutler hammer CH panels , using their ch breakers, probably use a breaker that does not trip quite as quickly as some others (current limiting and non-current limiting).
They both trip at overcurrents relatively quickly, but one allows a little overcurrent for motors with a big startup (momentary) draw... like AC etc. Hence that comment was made on HD page.
I do not think you have a choice in your panel to use any other type breaker.
I believe from the spec on your panel, you want the CH style breaker.
Maybe one of our real knowledgeable electrical men will chime in and confirm or explain.
Best
Peter
Old 05-24-2013, 10:10 AM   #11
jbfan's Avatar
Rewards Points: 544
Still good to go!
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 03:35 PM
Cutler hammer tandem breakers Elear Electrical 3 06-16-2010 10:18 PM
rotary hammer drill ctkeebler Tools 8 04-10-2010 09:42 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 12:30 AM
