Cutler Hammer Main Service ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 03:43 PM   #1
Helping a friend... she has an older Cutler Hammer 200 amp main service panel outside on her pole below the meter. Her 200 amp main breaker sit's vertically and takes up half the available breaker spaces. There are only 8 slots left... 4 of these slots are being taken up by a single "long" 2 pole 100 amp breaker (4lug?).
Then she has a 2 pole 60amp and a 2 pole 30amp breaker..... so now all the slots are used...
Question 1, Could a horizontial 200amp main be installed instead of a verticall 200 amp breaker?... this would give some extra room.
Question 2, Can the long 100amp breaker be switched to a shorter 100amp breaker that only takes up 2 slots? Therby leaving room for another 2 pole breaker. This 100amp breaker feeds her house panel.
I am not sure if her box is a BR or CH type
TDMcGinniss is offline   Reply With Quote
Old 01-31-2014, 03:53 PM   #2
Sparky
Rewards Points: 510
there is no horizontal 200a breaker
yes the 100a breaker is the older long style and can be replaced with a newer style 'short' version.
I can almost guarantee she has the CH series. The Handles will be tan, and the breakers will only be approx 3/4" per pole if they are.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
TDMcGinniss (01-31-2014)
Old 01-31-2014, 04:18 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is a good chance that the stabs the breakers clip onto are only rated for 100A and that would be why the full size breaker is installed, so you cannot install a breaker across from it.
The Following User Says Thank You to k_buz For This Useful Post:
plummen (01-31-2014)
Old 01-31-2014, 05:02 PM   #4
Well ok then.......I somehow knew this was not going to be a "simple" fix
So, is there a way I can tell what the stabs are rated for? It is a fairly large wire that feeds the whole house from that one 100amp breaker. And it is a CH model 200 amp breaker box.
Thanks All
Old 01-31-2014, 05:39 PM   #5
k_buz's Avatar
If you could find a model number, that would help, or you can look at the sticker inside the panel. It should tell you there.
Old 01-31-2014, 05:46 PM   #6
ok thanks... i won't be able to look at her panel until sunday.
Old 01-31-2014, 10:52 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Take pictures while your there. It helps us see exactly what you have.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Tandem breaker positions in main service panel elmaur Electrical 14 05-11-2012 01:28 PM
Main Service Question raleighthings Electrical 10 10-05-2011 12:35 PM
Question about main service line connections greendog Electrical 7 04-23-2011 12:38 AM
Can H. O. Install new UG Main service? calstonx Electrical 16 02-24-2009 07:07 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
